+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 3
    Points: 2,765, Level: 12
    Join Date
    Jan 2005
    Posts
    167
    Points
    2,765
    Level
    12
    Need coaxial cable design for HFSS simulation
    Hello everyone,
    I am starting on an antenna related simulation using HFSS 9.2.
    1 - I was wondering if anyone has a simple coaxial cable desing that I can import into my project to feed the antenna?
    2 - For an antenna simulation should i use a driven terminal solution setup?
    Thank you
    Cat
    •   Alt5th May 2005, 10:36
      advertising
  2. #2
    Full Member level 1
    Points: 2,713, Level: 12
    Join Date
    Sep 2004
    Posts
    114
    Points
    2,713
    Level
    12
    hfss coaxial cable
    Quote Originally Posted by Catalyst
    Hello everyone,
    Thank you
    Cat
    this is really simple :)
    1 members found this post helpful.
    •   Alt7th May 2005, 11:30
      advertising
  3. #3
    Member level 1
    Points: 2,249, Level: 10
    Join Date
    Nov 2003
    Switzerland
    Posts
    33
    Points
    2,249
    Level
    10
    coaxial cable hfss
    We ran a complete set of test on HFSS. check the zipped pdf. It's written in german though. Just ask if you have questions.
    Hope it helps.
    D.
    2 members found this post helpful.
    •   Alt10th May 2005, 07:37
      advertising
  4. #4
    Newbie level 3
    Points: 895, Level: 6
    Join Date
    Feb 2008
    Posts
    Points
    895
    Level
    coaxial cable in hfss
    thank you very much
