+ Post New Thread
Results 1 to 1 of 1
  1. #1
    Junior Member level 1
    Points: 202, Level: 2
    Join Date
    Apr 2017
    Posts
    16
    Points
    202
    Level
    Error in interface connection
    Hi ,
    I am getting following error. Please someone give idea about this error.
    Error:
    *E PCIONC expression connected to an 'inout' port must be collapsible..
    Interface instance
    Code Verilog - [expand]
    DDR4_if mic_ddr_if();
    Dut instance
    ddr_chip ddr4 (.iDDR4(mic_ddr_if))
    Below I mentioned the interface file...
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    interface DDR4_if #(parameter CONFIGURED_DQ_BITS = 8) ();
    timeunit 1ps;
    timeprecision 1ps;
    import arch_package::*;
    parameter CONFIGURED_DQS_BITS = (16 == CONFIGURED_DQ_BITS) ? 2 : 1;
    parameter CONFIGURED_DM_BITS = (16 == CONFIGURED_DQ_BITS) ? 2 : 1;
    logic[1:0] CK; // CK[0]==CK_c CK[1]==CK_t
    logic ACT_n;
    logic RAS_n_A16;
    logic CAS_n_A15;
    logic WE_n_A14;
    logic ALERT_n;
    logic PARITY;
    logic RESET_n;
    logic TEN;
    logic CS_n;
    logic CKE;
    logic ODT;
    logic[MAX_RANK_BITS-1:0] C;
    logic[MAX_BANK_GROUP_BITS-1:0] BG;
    logic[MAX_BANK_BITS-1:0] BA;
    logic[13:0] ADDR;
    logic ADDR_17;
    wire[CONFIGURED_DM_BITS-1:0] DM_n;
    wire[CONFIGURED_DQ_BITS-1:0] DQ;
    wire[CONFIGURED_DQS_BITS-1:0] DQS_t;
    wire[CONFIGURED_DQS_BITS-1:0] DQS_c;
    logic ZQ;
    logic PWR;
    logic VREF_CA;
    logic VREF_DQ;
    endinterface
    Thanks
    Venkat
    •   Alt14th December 2017, 06:23
      advertising
