T
treez
Hello,
We have an open collector comparator (TS391ILT) in our non-isolated offline LED lamp.
It sometimes trips due to noise. We wish to try and assess how to reduce the noise.
The Lamp has no AC input filter, as it is mostly linear regulator based.
The comparator is connected as per the attached schematic.
(The input signal comes from a 220R resistor in series with the output of an opamp. The 8V3 reference is from the output of an opamp connected as a noninverting amplifier)
Even when the input signal to the comparator is continuously high (ie 12V), the comparator still sometimes trips (presumably due to noise) and gives a high pulse at its output. In fact, it’s a little more involved than this, because when we connect the product to the mains via an isolation transformer, the comparator does **not** trip and go output_high when its input signal is continuously high. So in other words, powering the product through a mains isolation transformer makes the product less noisy. (and thus prevents noise tripping of the comparator)
Do you believe that the leakage inductance of the mains isolation transformer, and its parasitic Live/Neutral capacitance, is actually filtering out the noise from the mains and stopping it from pervading around the LED lamp? Also, do you believe that a very long length of mains cable to the lamp would have (to a degree) the same parasitic effect as the mains isolation transformer?...ie, in terms of having a stray inductance and capacitance (albeit smaller than that of the isolation transformer) which acts as a filter?….or alternatively, do you think that a long length of mains cable leading to the lamp would actually bring more mains bourne noise to the product, by acting as an “antenna”?
TS391ILT comparator:
https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.CD00001660.pdf
