[General] help me with the coding assembly language
nanaie96
Newbie level 2
Hey!
Im searching for the coding bulb relay interfacing with 8051 by using mcu 8051 ide.
can someone help me with the coding?:smile:
What have you done so far?
You need some requirement/specifiacation.
You need a flow chart.
Usually you need a schematic or at least a wiring information
You need to write code
You need to test your code
Thanks for the reply.
actually im on my microprosser mini project and the given title is smart classroom. My lecturer asked to make a bulb lights on instead of the led using AT89S52.
