caliber pex warnings: port name on the net not valid for netlisting; net id used instead
sanjaysharmaiitk
Member level 1
KANPUR
calibre pex warnings: port name on net not valid for netlisting; net id used instead
During LVS and PEX of UART layout to cdl netlist of UART in virtuoso some warning are coming.
There are no error in DRC , LVS and PEX.
warnings :
TEXT PRINT MAXIMUM limit of 1000 exceeded. 189 object(s) not printed.
Top level port name "RX/n_73" at location (413,711.76) on net 1 not valid for netlisting; net id used instead.
Top level port name "RX/n_10" at location (407.96,722.96) on net 6 not valid for netlisting; net id used instead.
Top level port name "RX/n_71" at location (409.64,707.28) on net 8 not valid for netlisting; net id used instead.
why are these warning coming .
they may be dangerous or not.
if they can not be ignored how to remove these warnings.
Re: calibre pex warnings: port name on net not valid for netlisting; net id used ins
You may ignore these warnings, I think - if you don't need to find your port names in the netlist.
AFAIR the netlister doesn't accept port names containing a slash (/). If you want to retrieve your port names in the netlist, prior to netlisting replace the slashes in your port names by (e.g.) underscores (_) :
RX/n_73 --> RX_n_73​
