Results 1 to 5 of 5
    Full Member level 3
    Points: 1,605, Level: 9
    chandu.kurapati's Avatar
    Oct 2013
    Bengaluru, India
    186
    1,605
    9
    Question Related to the typecasting from bool to char
    What happens when we typecast the bool variable to char and vice versa char variable to bool??
    Anyone please explain with example.
    Thanks & Regards,
    CHandu.K
    Reagrds,
    Chandu.Kurapati
    Did you find this post helpful? Click: Yes
    •   Alt7th December 2017, 05:54
      advertising
    Points: 8,055, Level: 21
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,443
    8,055
    21
    Re: Question Related to the typecasting from bool to char
    I think it is the same.
    Love me or hate me. All infractions will be ignored.
    •   Alt7th December 2017, 09:30
      advertising
    Points: 237,342, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,068
    237,342
    100
    Can't be answered generally. Bool e.g. defaults to 32 bit with some 32-bit compilers. On PIC processors, bool might be a single bit variable type.
    •   Alt7th December 2017, 09:43
      advertising
    Points: 8,139, Level: 21
    Jun 2009
    Japan
    1,054
    8,139
    21
    Hello Easyrider!
    I think for the data size, you're right, although FvM says that some compiler default to 32 bits.
    In general, the cast does nothing except giving a hint to the compiler on how to interpret it.
    The data itself does not change. For example, if you read a stream of uint8 from the serial port
    and want to print if with printf, it simply does nothing, but will tell the comiler to interpriet the
    uint8 * stream as char *, and that's it. Not even 1 bit of the stream will change.
    Now that's the same for bools. If they default to uint8, then a cast to bool tells the compiler to
    interpret it as a bool.
    And if you have a bool returning function like bool IsAscii(char c);, then if you have these statements:
    uint8 a;
    a = IsAscii('a');
    then some compiler will start yelling because you assign a bool to a variable which is uint8, (although
    it's the same). And some other compiler will not even issue a warning.
    Dora.
    Points: 24,730, Level: 38
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,434
    24,730
    38
    Blog Entries
    The "vice versa" means lose of information, any value different from Zero would yield true, therefore it is not exactly a typecasting opperation but rather a logical evaluation (the inverse opperation would not give the original value).
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
