+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 43, Level: 1
    Join Date
    Nov 2017
    Posts
    Points
    43
    Level
    How to run two module in series using verilog
    Hello, The following code is compiled and is working in parallel, Please help me to make these code work sequentially, i.e after stage1 counter should reset itself and starts from 0 for the stage2. The following codes has Module1- stage1 and module2-stage2.
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    module stage1(
                        input Clk, //50 Hz clock
                        input x0,
                        input reset,
                        output reg y0,y1,y2,y3,y5,y7,y10,y15,
                        output reg stage1_done
                reg [15:0] counter = 0;
                parameter F = 50;
                always@ (posedge Clk or posedge reset)
                    if(reset) begin
                        counter <= 0;
                        {y0,y1,y2,y3,y5,y7,y10,y15} <= 8'b00000000;
                        stage1_done <= 0;
                    end else begin
                        if(x0 == 1) begin
                            if(counter == 18*F)
                                stage1_done <= 1;
                            else begin
                                counter <= counter + 1;
                                stage1_done <= 0;
                            end
                            if(counter >= 1*F && counter < 10*F)
                                y0 <= 1;
                            else
                                y0 <= 0;
                            if(counter >= 1*F && counter < 17*F)
                                y1 <= 1;
                            else
                                y1 <= 0;
                            if(counter >= 1*F && counter < 9*F)
                                y2 <= 1;
                            else
                                y2 <= 0;
                            if(counter >= 11*F && counter < 16*F)
                                y3 <= 1;
                            else
                                y3 <= 0;
                            if(counter >= 1*F && counter < 18*F)
                                y5 <= 1;
                            else
                                y5 <= 0;
                            if(counter >= 1*F && counter < 5*F)
                                y7 <= 1;
                            else
                                y7 <= 0;
                                y10 <= 1;
                            else
                                y10 <= 0;
                            if((counter >= 2*F && counter < 9*F) || (counter >= 13*F && counter < 7*F))
                                y15 <= 1;
                            else
                                y15 <= 0;
                        end
                    end
                endmodule
            module stage2(
                    input x0,
                    input reset,
                    output reg y1,y3,y5,
                    output reg stage2_done
            parameter F = 50;
                if(reset) begin
                    counter <= 0;
                    {y1,y3,y5} <= 3'b000;
                    stage2_done <= 0;
                end
            else begin   if(x0 == 1) begin
                    if(counter == 8*F)
                        stage2_done <= 1;
                    else begin
                        stage2_done <= 0;
                    end
                    if(counter >= 1*F && counter < 8*F)
                        y1 <= 1;
                    else
                        y1 <= 0;
                        y3 <= 1;
                    else
                        y3 <= 0;
                        y5 <= 1;
                    else
                        y5 <= 0;
                    end
                end
            endmodule
    •   Alt7th December 2017, 03:21
      advertising
  2. #2
    Super Moderator
    Points: 53,103, Level: 56
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster
    Join Date
    Apr 2014
    Posts
    10,693
    Points
    53,103
    Level
    56
    Re: How to run two module in series using verilog
    The description is a bit vague. A flow chart could help to clarify things.
    I assume you need a state machine.
    Read about them to find out if this is what you need.
    Klaus
    Please don´t contact me via PM, because there is no time to response to them. Thank you.
  3. #3
    Advanced Member level 5
    Points: 35,071, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,426
    Points
    35,071
    Level
    45
    They would still be "in parralell", but you would need some extra controller logic to sequence the two modules.
    But why would you do this? it would be a very inefficient pipeline and half your potential throughput.
    •   Alt7th December 2017, 08:24
      advertising
  4. #4
    Join Date
    Nov 2017
    Posts
    Points
    43
    Level
    The module of stage 1 and stage 2 are in a flow of the process, when stage 1 is completed then stage 2 starts.
    I need a solution, in which I can reset the counter value at stage 1 and reset the counter to count from zero at stage 2.
    Since, I have provided the condition in which stage1_done output is high then stage 1 is completed but making counter to reset, I am confused and not able to work on it.
  5. #5
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,426
    Points
    35,071
    Level
    45
    The way you describe it, you seem to think Verilog is a programming language - it is a hardware description language. Think of each module as a chip on a circuit board - you cannot simply add and remove chips during run time. They are there all the time and the chips work by controlling the pins. The same is true of your verilog module.
    •   Alt7th December 2017, 19:47
      advertising
  6. #6
    Join Date
    Nov 2017
    Posts
    Points
    43
    Level
    I agree and I am working on it, but getting hard time to resolve.
    Will surely display the code if I come up with any solution to it, in the meanwhile suggestion and solutions are most welcome.
  7. #7
    Super Moderator
    Points: 27,821, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,358
    Points
    27,821
    Level
    40
    Quote Originally Posted by TrickyDicky View Post
    I think the code is not very well written regardless of it being thought of as software or hardware. It looks like the code is starting a bunch of pulses all aligned and shutting each one off delayed from each other. I really dislike the use of begin-end in some spots and not in others, I'd rather see consist use of begin-end even when it can be left off. especially as they don't use the recommended format for an if-else without begin-end.
    If you want the second FSM to start when the first is finished, then use the done signal to start the second FSM by having an IDLE state that just stays in that state until the first FSM is "done", once it signals done the second FSM exits IDLE and does whatever it needs to do. Before you ask I'm not supplying you with a code example.
