as90
In Synopsys PrimeTime, what would be an effective way to dump out delays and slews at all arcs and pins in the design? I've written a tcl script to achieve that but on a 160K cell design it takes more than 10min. Whereas report timing takes only half a minute. So I'm guessing that there must be some more efficient way to achieve this. Tcl script that I wrote looks like following:
Where, "clb_show_arcs" is another procedure, a part of which is shown below:
Large runtime is not due to file I/O caused by the echo at the bottom of clb_show_arcs procedure. Even if I comment that out, runtime to traverse over all the arcs and extracting delay, slew and ceff values at appropriate arcs/pins takes more than 10min.
Is there a more efficient way out there? Do I need to set some variables?
Thanks
proc print_arcs_for_calibration {} {
set outfile "pt_val_clb.txt"
exec rm -f $outfile
foreach_in_collection xyz [get_ports] {
set pn [get_attribute $xyz full_name]
set dir [get_attribute -class port $pn port_direction]
if {$pn!="ispd_clk" && $dir!="out"} {
clb_show_arcs -from $pn >> $outfile
foreach_in_collection xyz [get_cells] {
set is_seq [get_attribute $xyz is_sequential]
set cn [get_attribute $xyz full_name]
set opn "$cn/o"
clb_show_arcs -to $opn >> $outfile
clb_show_arcs -from $opn >> $outfile
proc clb_show_arcs {args} {
foreach_in_collection arc [eval [concat get_timing_arcs $args]] {
set is_cellarc [get_attribute $arc is_cellarc]
set fpin [get_attribute $arc from_pin]
set tpin [get_attribute $arc to_pin]
set rise [get_attribute $arc delay_max_rise]
set fall [get_attribute $arc delay_max_fall]
set from_pin_name [get_attribute $fpin full_name]
set to_pin_name [get_attribute $tpin full_name]
echo [format "%s %s %s %s %s %s %s %s %s %s %s" \
$riseSlewIn $fallSlewIn $from_pin_name $to_pin_name \
$rise $fall $is_cellarc $ceffR $ceffF $riseSlewOut \
$fallSlewOut]
Thanks
