Results 1 to 2 of 2
    Newbie level 6
    Points: 327, Level: 3
    Aug 2016
    11
    327
    TCP connection using W5500 IC problem
    Hi
    I have made my own board using W5500 IC. I set the W5500 to work in TCP Server. I can correctly Configure any registers of W5500 by SPI Interface. After setting W5500 in TCP server and get it on listen mode, when i try to connect it using hercules software, i can't connect correctly and i face with this:
    can any one help me to find out problem?
    •   Alt3rd December 2017, 22:35
      advertising
    Points: 24,714, Level: 38
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,432
    24,714
    38
    Blog Entries
    Re: TCP connection using W5500 IC problem
    It would help to clarify a bit if you also inform how your local network is configured (DHCP, proxy, DNS, etc ...). Did you try seeing what appear at any network tool, eg IPCONFIG on Windows ?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
