Audioguru
Advanced Member level 7
- Joined
- Jan 19, 2008
- Messages
- 9,456
- Helped
- 2,151
- Reputation
- 4,302
- Reaction score
- 2,008
- Trophy points
- 1,393
- Location
- Toronto area of Canada
- Activity points
- 59,709
ANY audio circuit that uses a dual supply can be biased at half the supply voltage and use a more simple single supply.
A precision rectifier circuit that uses a dual supply usually needs diodes to do the rectifying, but a precision rectifier circuit using an opamp that has inputs that go all the way down to its negative supply can use an inverting opamp circuit without any diodes and it rectifies perfectly.
A bandpass filter circuit can use a dual supply or a single supply, then its output can be rectified so that it is only positive levels.
