NewbeeAVR
Junior Member level 2
I have written code to read using AVR TWI interface. I am interfacing it to DS1307 later. But it is not working. To know execution at specific points I have put LEDs they are interfaced to PORTA.
The problem is instruction after Repeated Start are not working properly. I have checked status code after repeated start it should be 0x10, but it is 0x28 that is displayed on PORTB. I am testing it in Proteus with DS1307. I am reading location from 0x01 to 0x06 of DS1307.
Device ATmega32
Device ATmega32
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 #include <avr/io.h> #define RTC_ADDRESS 0b1101000 //7-bit DS1307 address unsigned char Data[10]; unsigned char SLA_R,SLA_W; void Initialize(unsigned char TWISlaveAddress) { SLA_R = ((TWISlaveAddress << 1) | 0x01); SLA_W = (TWISlaveAddress << 1); TWBR = 50; //By default prescalar is 1, TWSR_TWPS1 = 0, TWSR_TWPS0 = 0 TWCR = (1 << TWEN); } void Read(unsigned char TWIReadStartAddress, unsigned char TWIReadByteCount, unsigned char *TWIDestinationArrayR) { TWCR |= (1 << TWINT) | (1 << TWSTA); //Send START while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 if ((TWSR & 0xF8) == 0x08) //START sent PORTA |= (1 << PA0); TWDR = SLA_W; TWCR |= (1 << TWINT); //Clear TWINT to send SLA_W while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 if ((TWSR & 0xF8) == 0x18) //SLA_W transmitted, ACK received PORTA |= (1 << PA1); TWDR = TWIReadStartAddress; TWCR |= (1 << TWINT); //Clear TWINT to send Address while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 if ((TWSR & 0xF8) == 0x28) //Data byte transmitted, ACK received PORTA |= (1 << PA2); //Repeated START TWCR |= (1 << TWINT) | (1 << TWSTA); //Send Repeated START while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 PORTB = (TWSR & 0xF8); if ((TWSR & 0xF8) == 0x10) //Repeated START transmitted PORTA |= (1 << PA3); TWDR = SLA_R; TWCR |= (1 << TWINT); //Clear TWINT to send SLA_R while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 if ((TWSR & 0xF8) == 0x40) //SLA_R transmitted, ACK received PORTA |= (1 << PA4); TWCR |= (1 << TWEA); //Return ACK after each byte read unsigned char TWIReadCount; for (TWIReadCount = 0; TWIReadCount <= (TWIReadByteCount - 1); TWIReadCount++) { TWCR |= (1 << TWINT); //Clear TWINT to read (next) Data while (!(TWCR & (1 << TWINT))); //Wait until TWINT = 1 if ((TWSR & 0xF8) == 0x50) //Data byte received, ACK returned { *TWIDestinationArrayR = TWDR; TWIDestinationArrayR++; } } PORTA |= (1 << PA5); TWCR &= (~(1 << TWEA)); //Return NACK after last byte read TWCR |= (1 << TWINT) | (1 << TWSTO); //Send STOP while(TWCR & (1 << TWSTO)); //Wait until bus release PORTA |= (1 << PA6); } int main() { DDRA = 0xFF; DDRB = 0xFF; Initialize(RTC_ADDRESS); Read(0x01, 6, &Data[0]); return 0; }
