+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 3
    Points: 322, Level: 3
    Join Date
    Jul 2017
    Posts
    54
    Points
    322
    Level
    modelsim error during RTL simulation
    hi all,
    I'm getting an error while doing RTL simulation on quartus, the comments are pasted below
    # Reading C:/intelFPGA/17.0/modelsim_ase/tcl/vsim/pref.tcl
    # do po_run_msim_rtl_vhdl.do
    # if {[file exists rtl_work]} {
    # 	vdel -lib rtl_work -all
    # vlib rtl_work
    # vmap work rtl_work
    # Model Technology ModelSim - Intel FPGA Edition vmap 10.5b Lib Mapping Utility 2016.10 Oct  5 2016
    # Copying C:/intelFPGA/17.0/modelsim_ase/win32aloem/../modelsim.ini to modelsim.ini
    # Modifying modelsim.ini
    # vcom -87 -work work {C:/intelFPGA/17.0/signaltptutorial/po.vhd}
    # Model Technology ModelSim - Intel FPGA Edition vcom 10.5b Compiler 2016.10 Oct  5 2016
    # Start time: 19:34:43 on Nov 30,2017
    # vcom -reportprogress 300 -87 -work work C:/intelFPGA/17.0/signaltptutorial/po.vhd
    # -- Loading package STANDARD
    # -- Loading package TEXTIO
    # -- Loading package std_logic_1164
    # -- Compiling entity po
    # -- Compiling architecture bhav of po
    # End time: 19:34:43 on Nov 30,2017, Elapsed time: 0:00:00
    # Errors: 0, Warnings: 0
    # vcom -87 -work work {C:/intelFPGA/17.0/signaltptutorial/simulation/modelsim/testebecnh.vhd}
    # vcom -reportprogress 300 -87 -work work C:/intelFPGA/17.0/signaltptutorial/simulation/modelsim/testebecnh.vhd
    # -- Loading package std_logic_textio
    # -- Loading package std_logic_arith
    # -- Loading package STD_LOGIC_UNSIGNED
    # -- Compiling entity testebecnh
    # -- Compiling architecture testebecnh_arch of testebecnh
    # vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -voptargs="+acc"  tb
    # vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -voptargs=""+acc"" tb
    # Start time: 19:34:44 on Nov 30,2017
    # ** Error: (vsim-3170) Could not find 'tb'.
    #         Searched libraries:
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/altera
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/220model
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/sgate
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/altera_mf
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/altera_lnsim
    #             C:/intelFPGA/17.0/modelsim_ase/altera/vhdl/fiftyfivenm
    #             C:/intelFPGA/17.0/signaltptutorial/simulation/modelsim/rtl_work
    # Error loading design
    # Error: Error loading design
    #        Pausing macro execution
    # MACRO ./po_run_msim_rtl_vhdl.do PAUSED at line 12
    Please anyone help me.
  2. #2
    Advanced Member level 3
    Points: 6,882, Level: 19
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    999
    Points
    6,882
    Level
    19
    Blog Entries
    Re: modelsim error during RTL simulation
    First tell us, what comes to your mind when you see the error message "** Error: (vsim-3170) Could not find 'tb'."
    Did you write this script yourself?
    Any please use "Code tags" when posting any type of code, be it RTL or some script (if I am not mistaken you are not posting for the 1st time in this forum).
    .....yes, I do this for fun!
    •   Alt30th November 2017, 15:51
      advertising
  3. #3
    Advanced Member level 5
    Points: 35,071, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,426
    Points
    35,071
    Level
    45
    As in the description, Modelsim could not find the tb module
  4. #4
    Points: 5,038, Level: 16
    Join Date
    Apr 2016
    Posts
    1,063
    Points
    5,038
    Level
    16
    just open 'testebecnh.vhd' and see if you have a "tb" in there. my guess it is called something else. this is debugging 101, I am sure your class/instructor has covered this.
    Really, I am not Sam.
    •   Alt30th November 2017, 16:52
      advertising
  5. #5
    Member level 3
    Join Date
    Jul 2017
    Posts
    54
    Points
    322
    Level
    Quote Originally Posted by ThisIsNotSam View Post
    I am not able to debug the issue. what you mean by tb in testbecnh.vhd?
  6. #6
    Join Date
    Apr 2016
    Posts
    1,063
    Points
    5,038
    Level
    16
    You should read a vhdl tutorial then if you don't know what entity you have in your testbench file.
  7. #7
    Member level 3
    Join Date
    Jul 2017
    Posts
    54
    Points
    322
    Level
    I got the solution, the test bench entity name was incorrect in compile test bench.
    everyone was once a beginner....
    •   Alt30th November 2017, 18:13
      advertising
  8. #8
    Join Date
    Apr 2016
    Posts
    1,063
    Points
    5,038
    Level
    16
    Quote Originally Posted by hareeshP View Post
    Sure. That being said, I still think you should read some vhdl / digital design material.
  9. #9
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,426
    Points
    35,071
    Level
    45
    probably, but testebecnh.vhd clearly exists as a file as otherwise there would have been an error.
    I guess the correct file actually has an entity called tb inside it. And testebecnh did not.
