JBOUN3
Is debouncing needed for very simple circuot?
Hello, and thanks again in advance.
I'm building a rather flashing LED circuit, at 4,9,10 and 40 Hz, for optigenetic and meditation thearpy.
The first version uses a 4060 IC, and until I can get the 3.932160 crystal that'll get me the 10 and 40 Hz exactly enough; within .01 Hz should be plenty precise enough. I'm using a simpler RC combination, should get me close enough to 40.0, with a little patience and perhaps a trim cap.
Second version will be a step up to a basic as possible microcontroller, probably an 8051 family uC.
Meanwhile here is my question: Do I need to study and calculate and include debouncing circuitry, or will the occasional bounce fall within reasonable close enough tolerance? Would bounces take place within the IC, or only on the way in from the RC (or crystal) oscillator - in other words, if a de-bouncing circuit is needed, would this be a single low-pass filter for the oscilator input clock, pin 11? Or... what?
Regards. JB
Regards. JB
