Results 1 to 15 of 15
    Points: 12,132, Level: 26
    Aug 2011
    2,469
    12,132
    26
    Multiple users of a DDR interface
    I have a DDR3 controller with a 128 bit wide data interface.
    Currently there're 5 users connected to using the following architecture:
    Each "user" has a 16 to 128 width converting FIFO. The application write data to the 16 bit side.
    Each of the 5 128 bit FIFO outputs is connected via a MUX to a custom arbiter I wrote.
    With every clock that the DDR3 controller is ready (wait signal inactive), the arbiter issues a select signal to the MUX, strobes a read signal to the appropriate FIFO and writes the data to a predetermined address range (that matches the FIFO number).
    The design works well at ~120 MHz but I doubt that it'll scale up well.
    I expect the 128 bit wide MUX to become a performance bottleneck as the number of users increases...
    How did you solve similar problems?
    Points: 27,821, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,358
    27,821
    40
    Re: Multiple users of a DDR interface
    Pipeline the multiplexer (and address/control) for maximum performance and maximum resource usage, peel off bits of the select and multiplex that subset of inputs and register the output, then multiplex the next set of inputs using the next set of select bits. Assuming a binary select and 6-input LUTs you should end up with two stages of 4-to-1 multiplexers for a 16-to-1 mux, with registers on the output of each stage.
    Aug 2011
    2,469
    12,132
    26
    This was my first thought a while ago...and it's probably what I'll do eventually...
    https://alteraforum.com/forum/showthread.php?t=54643
    But I'm asking about other approaches to this issue...
    Obviously anyone who tried to connect multiple users to a shared medium with a very wide bus - faced similar design challenges.
    So I'm thinking perhaps someone here implemented a different solution than the one I'm considering.
    •   Alt30th November 2017, 15:10
      advertising
    Advanced Member level 3
    Points: 6,882, Level: 19
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    999
    6,882
    19
    Blog Entries
    I had come across a design in which multiple FIFOs were to write data to an external DDR3 memory (in your case it would be 5 FIFOs of 5 users ).
    The FIFO interface signals were AXIS.
    So we had used the AXI Virtual FIFO Controller IP core. I am talking about Xilinx based designs.
    You may read here a bit and get some idea : https://www.xilinx.com/products/inte...ontroller.html
    If you look at the spec, PG038 November 18, 2015, Pg. 8 shows the top-level block diagram, you will get an idea as to what is happening. You don't need any custom Arbiter or MUX design, everything is saleable.
    .....yes, I do this for fun!
    •   Alt30th November 2017, 16:00
      advertising
    Points: 35,071, Level: 45
    Jun 2010
    6,426
    35,071
    45
    You dont specify what interface you're using?
    The Xilinx memory controller offers an AXI4 slave interface, and there is an axi interconnect IP for multiple masters to a Memory slave. THe interconnect has several configuration options, like buffer sizes and packet fifos for buffering data. Different masters can have different dwidths and all transactions will be converted inside the interconnect.
    Make your life easy, use existing IP for existing interfaces.
    Good thing about AXI4 is that it's pretty simple to plug AXIS into it.
    Aug 2011
    2,469
    12,132
    26
    I designed the custom arbiter for an Altera Cyclone V SOC implementation.
    At first, I tried to use the native QSYS interconnect but the timing performance and resource usage were VERY VERY POOR. Fmax was under 95MHz.
    I was surprised at first - but our ALTERA FAE confirmed that my Qsys design was optimal...
    This led me to try and design something of my own. The Fmax I got with the architecture I described is 124MHz with 1/5 the logic usage of the Qsys equivalent!
    Now, I'm working on a new design that will be implemented on a much bigger Xilinx Kintex Ultrascale FPGA.
    So I'm thinking whether or not to reuse my custom arbiter or to give Xilinx interconnect a try...
    •   Alt30th November 2017, 22:13
      advertising
  7. #7
    Jun 2010
    6,426
    35,071
    45
    Give the xilinx stuff a go. We use it at 200 MHz.
  8. #8
    Aug 2011
    2,469
    12,132
    26
    On what device?
  9. #9
    Jun 2010
    6,426
    35,071
    45
    Ultrascale.
    One thing to bare in mind that Xilinx stuff is all AXI - I dont know what your custom IP speaks.
  10. #10
    Aug 2011
    2,469
    12,132
    26
    It speaks Avalon which is almost the same...
    Do you know what arbitration scheme the AXI interconnect implements in case of multiple users?
    I know that Qsys uses weighted round robin...somewhat inefficient.
  11. #11
    Jun 2010
    6,426
    35,071
    45
    Almost the same, but you need to ensure that you set readyLatency to 0 to work with AXI
    The Xilinx AXI Interconnect can be configured to work with either round robin or weighted round robin. But it is fully pipelined (if you configure it that way).
    Read the interconnect documentation:
    https://www.xilinx.com/support/docum...terconnect.pdf
  12. #12
    Points: 4,845, Level: 16
    Feb 2015
    808
    4,845
    16
    Arbitration scheme and clock rate -- does this matter that much? You should design any algorithms to avoid small external memory accesses. If short accesses are needed, you should include a caching layer similar to the L1/L2 cache from modern CPUs. External memory interfaces like DDR* favor kilobyte sized accesses when possible.
    •   Alt1st December 2017, 12:13
      advertising
  13. #13
    Aug 2011
    2,469
    12,132
    26
    The Arbitration algorithm does start to matter when you approach the memory bandwidth limits...
  14. #14
    Jun 2010
    6,426
    35,071
    45
    Quote Originally Posted by shaiko View Post
    But why are you approaching the limits? is it because of small transfers? lots of row changes? Much easier to get the access sequence fixed (if possible) to save bandwidth that the complicated arbitration.
  15. #15
    Aug 2011
    2,469
    12,132
    26
    No. I use the memory very efficiently...long bursts and as much spatial locality as possible.
    With 5 users, I consume ~40% of the bandwidth - but as the design grows, more users will be added, so I'd like to work as efficiently as possible...
