Results 1 to 3 of 3
    Junior Member level 1
    Points: 147, Level: 1
    Aug 2017
    14
    147
    Programming an fpga board
    i have a board with 8 led and my circuit output is a 32 bit vector.
    my question is how an i write a ucf file and connect the output to the leds?
    is it possible to break output and use a key to see out put continuously.
    please help me.thanks
    •   Alt29th November 2017, 14:17
      advertising
    Points: 12,132, Level: 26
    Aug 2011
    2,469
    12,132
    26
    Re: programming an fpga board
    When you assign outputs you always do it per pin.
    I.E elements of the vector will be assigned to individual I/Os.
    Try to do it with the ISE GUI and see the generated UCF output.
    •   Alt29th November 2017, 22:42
      advertising
    Advanced Member level 3
    Points: 6,882, Level: 19
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    999
    6,882
    19
    Blog Entries
    You want to connect the complete 32bits output?
    In that case the 8 LEDs are are limitation. So what you can do is to introduce is 32:8 encoder and connect that output to the LEDs.
    .....yes, I do this for fun!
