Effect of high temperature on cntfet
tejashrimane
Newbie level 2
hello i am working cntfet i want to investigate efeect of diiferent temperature on drain current but when i change temperature there is no effect on its same for all temp
i am using standford university model of cntfet.
* Carbon Nanotube Field Effect Transistors
*             HSPICE Model
*	       Version 2.2.1
*   Copyright The Board Trustees of the Leland Stanford Junior University 2009
*   Albert Lin, Gordon Wan, Jie Deng, Prof. H-S Philip Wong
*   All Rights Reserved.
*   09/09/2008 Last Modified by Albert Lin.
*   Carbon Nanotube Field Effect Transistors Verilog-A implementation
*   based on
*   "A Circuit-Compatible SPICE model for Enhancement Mode Carbon
*   Nanotube Field Effect Transistors" by Jie Deng and H-S Philip Wong
*   Patent Pending.
*   File name: cnfet_sample.sp
* LICENSE AGREEMENT
* Stanford Leland Junior University and the authors ("Stanford")
* provide these model files to you subject to the License Agreement,
* which may be updated by us from time to time without notice to you.
* The most-up-to-date License Agreement can be found at
* **broken link removed**
*Sample HSPICE Deck
.TITLE 'IDS vs VGS for CNFET'
*For optimal accuracy, convergence, and runtime
.options POST
.options AUTOSTOP
.options INGOLD=2     DCON=1
.options GSHUNT=1e-12 RMIN=1e-15
.options ABSTOL=1e-5  ABSVDC=1e-4
.options RELTOL=1e-2  RELVDC=1e-2
.options NUMDGT=4     PIVOT=13
.param   TEMP=27
*Include relevant model files
.lib 'CNFET.lib' CNFET
*Beginning of circuit and device definitions
*Supplies and voltage params:
.param Supply=0.9
.param Vg='Supply'
.param Vd='Supply'
*Some CNFET parameters:
.param Ccsd=0      CoupleRatio=0
.param m_cnt=1     Efo=0.6
.param Wg=0        Cb=40e-12
.param Lg=32e-9    Lgef=100e-9
.param Vfn=0       Vfp=0
.param m=19        n=0
.param Hox=4e-9    Kox=16
* Define power supply
Vdd     Drain     Gnd     Vd
Vss     Source    Gnd     0
Vgg 	  Gate	Gnd	  Vg
Vsub    Sub       Gnd     0
* Main Circuits
* nFET
XCNT Drain Gate Source Sub NCNFET Lch=Lg  Lgeff='Lgef' Lss=32e-9  Ldd=32e-9
+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbn='Vfn' Dout=0  Sout=0  Pitch=20e-9  n1=m  n2=n  tubes=3
* pFET
*XCNT Drain Gate Source Sub PCNFET Lch=Lg  Lgeff='Lgef' Lss=32e-9  Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbp='Vfp' Dout=0  Sout=0  Pitch=20e-9  n1=m  n2=n  tubes=3
* nFET uniform-tubes model
*XCNT Drain Gate Source Sub NCNFET_uniform Lch=Lg  Lgeff='Lgef' Lss=32e-9  Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbn='Vfn' Dout=0  Sout=0  Pitch=20e-9  n1=m  n2=n   CNTPos=1 tubes=3
* pFET uniform-tubes model
*XCNT Drain Gate Source Sub PCNFET_uniform Lch=Lg  Lgeff='Lgef' Lss=32e-9  Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbp='Vfp' Dout=0  Sout=0  Pitch=20e-9  n1=m  n2=n   CNTPOS=0 tubes=3
* Measurements
* test nFETs, Ids vs. Vgs
.DC      Vgg   START=0     STOP='Supply'   STEP='0.3*Supply'
+ SWEEP  Vdd   START=0     STOP='Supply'   STEP='0.3*Supply'
.temp 100 150 200
* test pFETs, Ids vs. Vgs
*.DC      Vgg   START=0     STOP='-Supply'   STEP='-0.01*Supply'
*+ SWEEP  Vdd   START=0     STOP='-Supply'   STEP='-0.1*Supply'
.print I(Vdd)
.end
this is the netlist where i change temp
can any one help me out.
Re: effect of high temperature on cntfet
try for another model of cntfet.then u will get solution for it.
