HFSS radiation pattern
TXRX
Full Member level 2
I design 2 patch antenna on pcb, each of them there is a port, when i look on rediation pattern result, is the radiation pattern belong to both of them ? how i can see only the radiation pattern of one antenna ?
Thanks,
Doron
I think you are asking how do you excite only one of the antennas -- since the simulation results will include the effects of coupling between them.
Go into menu "HFSS"->"Fields"->"Edit Sources". Here you can control the excitations of your various ports.
Good Luck!
I enter to "Edit Sources" and see that both ports are unchecked, How i receive Radiation Pattern ?
Set the magnitude of the excitation (voltage or power) of the port you want to a non-zero value, and set the rest to 0. Then view the radiation pattern.
and the port that i does not want to excite how i terminate it to 50 ohm ?
If it's a wave port, it will automatically match itself to the transmission line you connect it to.
If it's a lumped port, you set its impedance (default should be 50 Ω).
