Results 1 to 12 of 12
    Junior Member level 3
    Points: 1,047, Level: 7
    Nov 2012
    26
    1,047
    7
    How to reduce noise of fan
    I have a system with 9 fans of 48V, 2.5A.
    they make a big noise, how can I reduce the noise there? any acoustic solution?
    Points: 19,641, Level: 33
    barry's Avatar
    Mar 2005
    California, USA
    3,785
    19,641
    33
    Re: How to reduce noise of fan
    •   Alt19th November 2017, 19:44
      advertising
    Points: 46,241, Level: 52
    Apr 2011
    Minneapolis, Minnesota, USA
    11,544
    46,241
    52
    I had a 5.25" hard drive in its own enclosure. The 2-inch fan was loud enough to remind me of a jet engine. The helpline said the fan had to run at high speed so it could reduce temperature to specs. I decided to quiet it down anyway. I installed a resistor inline. It reduced rpm. It also reduced cooling effect but I decided I could live with it.
    To create airflow under the disk, I raised it up on homemade standoffs. The drive gave me no trouble for the years I owned it.
    It occurred to me that I ought to install some kind of thermometer inside the enclosure. It would have been fun for me to construct an electronic circuit around a Radio Shack temperature sensor. But I didn't bother, as long as the drive worked okay.
    •   Alt20th November 2017, 05:06
      advertising
    Points: 53,016, Level: 56
    Most Frequent Poster
    Apr 2014
    10,674
    53,016
    56
    Active noise cancellation:
    I doubt that this guves goid results, because:
    * most of the noise is really "random" noise.
    * the source of the generating nouse is relatively big...and moving.
    Please donīt contact me via PM, because there is no time to response to them. Thank you.
    Points: 24,714, Level: 38
    andre_teprom's Avatar
    Nov 2006
    Brazil
    7,432
    24,714
    38
    Blog Entries
    If the fans are not internal coolers, perhaps adding external dust filter likewise these used on industrial cabinets could reduce a few, but I'm not so sure of the result.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt20th November 2017, 07:52
      advertising
    Nov 2012
    26
    1,047
    7
    what you mean by "random"?
  7. #7
    Apr 2014
    10,674
    53,016
    56
    "random" noise: Random frequencies, random phase, random amplitude.
    In opposite to a car engine, where there is a fundamental frequency (motor RPM) and itīs overtones (integer multiples of the fundamental frequency).
  8. #8
    Points: 237,321, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,068
    237,321
    100
    Is it 48V/2.5A each? If so, you are using high speed fans which are producing quite high noise sound level (e.g. 75 - 85 dBA) by design. If the high airflow is actually required by the application, there's little change to reduce the noise level without completely redesigning the cooling system. Temperature or power demand controlled fan speed may be an option to reduce at least the standby noise.
    Acoustic insulation might be an option if you have plenty of room.
    •   Alt20th November 2017, 09:56
      advertising
  9. #9
    Apr 2014
    10,674
    53,016
    56
    water cooling comes into my mind.
  10. #10
    Nov 2006
    Brazil
    7,432
    24,714
    38
    Blog Entries
    As mentioned above, by redesigning the whole (mechanical) system could achieve some result, as for example by increasing the heatsink area could reduce the airflow requirements.
  11. #11
    barry's Avatar
    Mar 2005
    California, USA
    3,785
    19,641
    33
    I don't know that it won't work. The principle is that you are adding noise of opposite polarity to the source so that the sum is a net cancellation. I don't think it matters if it's random or not. But I've been wrong before.
    The OP was asking for an acoustic solution. Water cooling is not an acoustic solution; however ear plugs would be.
  12. #12
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,068
    237,321
    100
    The below Wikipedia article discusses the effort and limitations of noise cancellation https://en.wikipedia.org/wiki/Active...l#Applications
    A general problem is that non-periodical (=random) noise above a certain frequency related to source dimensions and sound velocity can be neither canceled by feedback nor by signal prediction.
