+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 1
    Points: 703, Level: 5
    Join Date
    Nov 2014
    Posts
    35
    Points
    703
    Level
    Anti-jamming antennas
    Ive read some articles about anti-jamming GNSS antennas. Some antennas are said to resist jamming signal of 50V/m while others have 15dB J/S ratio. Well, both seem to be the specification describing the anti-jamming capability. Can they be compared somehow?
    Senmeis
    •   Alt19th November 2017, 07:23
      advertising
  2. #2
    Super Moderator
    Points: 237,342, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,068
    Points
    237,342
    Level
    100
    Re: anti-jamming antennas
    I presume they can be compared by putting in the received GNSS field strength.
    •   Alt19th November 2017, 18:22
      advertising
  3. #3
    Member level 1
    Join Date
    Nov 2014
    Posts
    35
    Points
    703
    Level
    Quote Originally Posted by FvM View Post
    Do you mean this comparison makes sense only if the input GNSS power is given?
    Senmeis
    •   Alt24th November 2017, 13:47
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,068
    Points
    237,342
    Level
    100
    Re: Anti-jamming antennas
    Input power varies according to antenna, the primary unit of received signal strength is power density or field strength, both are related by impedance of free space. The field strength probably varies with satellite elevation angle.
    A typical GPS receive field strength is in a V/m range, e.g. 2 V/m corresponds to -135 dBm with 0 dBi antenna gain.
    You can refer to an R&S application note for the calculation https://cdn.rohde-schwarz.com/pws/dl..._Estimator.pdf
