Xilinx ISE - readmemh system task taking too much time
NikosTS
Xilinx ISE - readmemb system task taking too much time
Hello everybody,
I have a rather large .txt file ( around 95 Mb ) that i need to store in a memory using the $readmemb system task. However, i left the design to synthesize overnight ( more than 12 hours ) and still the process is stuck at "reading initialization file".
Is it normal to take that much? And what could i do in order to accelerate it?
Thank you in advance,
Nikos
You may use .ini file to initialize the memory, I am not sure if the readmemb is synthesizable or not
