Results 1 to 2 of 2
    Points: 335, Level: 3
    Jan 2017
    43
    335
    Xilinx ISE - readmemb system task taking too much time
    Hello everybody,
    I have a rather large .txt file ( around 95 Mb ) that i need to store in a memory using the $readmemb system task. However, i left the design to synthesize overnight ( more than 12 hours ) and still the process is stuck at "reading initialization file".
    Is it normal to take that much? And what could i do in order to accelerate it?
    Thank you in advance,
    Nikos
    •   Alt14th November 2017, 11:36
      advertising
    Full Member level 3
    Points: 2,428, Level: 11
    Nov 2009
    Pakistan
    183
    2,428
    11
    Re: Xilinx ISE - readmemh system task taking too much time
    You may use .ini file to initialize the memory, I am not sure if the readmemb is synthesizable or not
