Usually, you tapeout your chip with the default (recommended) values of margin.
If you are planning to play with EMA values on the real chip - do not connect constant values to the EMA pins, but connect them to register. So, you will be able to modify values in the silicon.
After the chip will be fabricated you can play with margin values, until the memory still works (in all possible environment conditions) on all your chips.
