LC network synthesis: 2nd example and questions
niki
Member level 4
Switzerland
8 networks have 8 different input signals but all output signals are identical!
(see attachement)
Some informations about the networks:
All networks can be realized with positive values ​​of the elements
All networks have the same insertion loss (S21dB)
All networks have the same input return loss (S11dB)
All networks have the same output return loss (S22dB)
How is that possible?
What special requirements for the networks must be met?
Regards
Peter
  • eda2.pdf
Obviously, their frequency characteristics are different in "eda2.pdf".
Smply 8 networks have same frequency charateristics regarding frequency band of output signal.
In the attachment i've placed 3 examples with elements values. Therefore you can check the networks with simulations in the frequency and time domain.
Interesting frequency range: 20 kHz ... 1 MHz
Source signal (time domain): Square wave
The question still remains: how do the networks differ?
  • eda_zwei.pdf
Your issue is very simple completely as same as your previous thread.
https://www.edaboard.com/showthread.php?t=372482#7
Again, answer is https://www.edaboard.com/showthread.php?t=372889#2
Show us frequency characteristics of mag(S11) and phase(S11).
Then consider fourier expansion of source signal.
{S11, S12, S21, S22} is a unitary matrix, since networks are lossless.
So the followings are satisfied.
|S11|^2 + |S21|^2 = 1
|S12|^2 + |S22|^2 = 1
conj(S11)*S12 + conj(S21)*S22 = 0
From reciprocity, S12 = S21.
|S21|^2 = 1 - |S11|^2
|S11| = |S22|
There are two options for S11 and S22 in stop band.
One is open.
The other is short.
I assume S11=0 and S22=0 for pass band.
And |S11|=1 and |S22|=1 for stop band.
For lower stop band
(Case-1)
S11=1
S22=1
(Case-2)
S11=1
S22=-1
(Case-3)
S11=-1
S22=1
(Case-4)
S11=-1
S22=-1
These are true for upper stop band.
Here are the plots of the eight networks
S11 (Smithchart)
Phase(S11)
Mag(S11)
Mag(S21)dB
How should I relate the S11 plots to the claim in post #1?
Only the magnitude of S11 are identical (Return Loss), but the Phase(S11) are different for all networks.
This leads to the pretty curves in the smith chart!
And that is also the cause for different input signals in the time domain.
Thanks. I meaned to see different magnitudes in the Smith chart, but they aren't.
I wonder what's the conclusion from this interesting lesson about phase and magnitude of transfer functions.
If we e.g. design a chebychev or cauer filter, the specification sets s21 magnitude only. But the tabulated filter designs give a full set of complex poles and zeros, thus setting also s21 phase. Do I miss something?
This is not interesting at all.
It is very easy things.
Wrong.
We start with polynomial, H(s)*H(-s), that is, zeros and pole.
Strictrly speaking, it is s11 not s21.
And relative phase is free to choose.
However we treat s21 instead of s11, since |S11|^2 + |S21|^2 = 1.
We can characterize reciprocal and lossless 2-port network by only s11.
I'm not particularly referring to reciprocal etc. networks, but to filter application. Implementation can be different, e.g. LC, active filter, digital. I don't particularly care for s11.
Your hint to relative phase answers the question for me. Although an offset Δφ(s21) is free to choose, dφ/dω(s21) isn't. This effectively fixes φ(s21) for a passive LC implementation, but not φ(s11).
