Results 1 to 4 of 4
    [Moved]How to convert a vhdl code to verilog code
    this is the code for converting decimal to binary in vhdl.How to cinvert a vhdl code to verilog code
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    library IEEE;
     use ieee.std_logic_1164.all;
    use IEEE.numeric_std.all;
    entity decimal is
    end decimal;
    architecture beh of decimal is
    signal  my_sulv1 : std_ulogic_vector(15 downto 0);
    signal my_int : integer range 0 to 100;
    signal  my_sulv2 : std_ulogic_vector(15 downto 0);
    begin
    my_int <= to_integer(unsigned(my_sulv1));
    my_sulv2 <= std_ulogic_vector(to_unsigned(my_int, 16));
    end beh;
    •   Alt11th November 2017, 18:58
      advertising
    Member level 4
    Points: 489, Level: 4
    Apr 2017
    75
    489
    Re: How to cinvert a vhdl code to verilog code
    You can use for example this translator: http://www.edautils.com/vhdl2verilog.html
    •   Alt11th November 2017, 20:57
      advertising
    Points: 237,342, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,068
    237,342
    100
    I believe the question involves a misunderstanding. The VHDL integer type isn't specifically related to decimal number representation. Integer quantities can be represented with different base, e.g. decimal, hexadecimal, octal, binary.
    Integer is a general-purpose type that can be either used abstracted from logic hardware, or infer signed and unsigned numbers in hardware.
    The shown code doesn't involve an actual conversion, except for a number truncation to 7 bit unsigned (in hardware synthesis) or 0 to 100 range check in simulation.
    •   Alt12th November 2017, 12:17
      advertising
    Advanced Member level 3
    Points: 6,874, Level: 19
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    999
    6,874
    19
    Blog Entries
    Other than the correctness of the code, I have inhibitions on the free software/s that claim to convert VHDL to Verilog and vice-versa (#2).
    Basically the best way is to do it manually. But this not necessary (if this is not your homework assignment) as most simulators and synth engines support mixed mode HDL designs.
    Also you have posted this in the wrong sub-forum.
    .....yes, I do this for fun!
