+ Post New Thread
Results 1 to 4 of 4
  1. #1
    [Moved]How to convert a vhdl code to verilog code
    this is the code for converting decimal to binary in vhdl.How to cinvert a vhdl code to verilog code
    [syntax=vhdl]
    library IEEE;
    use ieee.std_logic_1164.all;
    use IEEE.numeric_std.all;
    entity decimal is
    end decimal;
    architecture beh of decimal is
    signal my_sulv1 : std_ulogic_vector(15 downto 0);
    signal my_int : integer range 0 to 100;
    signal my_sulv2 : std_ulogic_vector(15 downto 0);
    begin
    my_int <= to_integer(unsigned(my_sulv1));
    my_sulv2 <= std_ulogic_vector(to_unsigned(my_int, 16));
    end beh;[/syntax]
    •   Alt11th November 2017, 18:58
      advertising
  2. #2
    Member level 5
    Points: 563, Level: 5
    Join Date
    Apr 2017
    Posts
    86
    Points
    563
    Level
    Re: How to cinvert a vhdl code to verilog code
    You can use for example this translator: http://www.edautils.com/vhdl2verilog.html
    •   Alt11th November 2017, 20:57
      advertising
  3. #3
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    I believe the question involves a misunderstanding. The VHDL integer type isn't specifically related to decimal number representation. Integer quantities can be represented with different base, e.g. decimal, hexadecimal, octal, binary.
    Integer is a general-purpose type that can be either used abstracted from logic hardware, or infer signed and unsigned numbers in hardware.
    The shown code doesn't involve an actual conversion, except for a number truncation to 7 bit unsigned (in hardware synthesis) or 0 to 100 range check in simulation.
    •   Alt12th November 2017, 12:17
      advertising
  4. #4
    Points: 7,114, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,032
    Points
    7,114
    Level
    20
    Blog Entries
    Other than the correctness of the code, I have inhibitions on the free software/s that claim to convert VHDL to Verilog and vice-versa (#2).
    Basically the best way is to do it manually. But this not necessary (if this is not your homework assignment) as most simulators and synth engines support mixed mode HDL designs.
    Also you have posted this in the wrong sub-forum.
    .....yes, I do this for fun!
