- Joined
- Jul 4, 2009
- Messages
- 16,232
- Helped
- 5,140
- Reputation
- 10,309
- Reaction score
- 5,120
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 137,370
You are looking at a completely different scenario. The article mentions high speed data lines and the need to use a GDT to minimize capacitive loading, not very low impedance power lines. The schematic also shown the current clamping to "AGND0" which to most would suggest an analog or 'clean' ground rather than one side of the AC line.
Try an experiment, it's something I developed as a student project years ago, it will safely identify spikes large enough to trigger the GDT:
1. Use a wire ended neon indicator lamp. Wrap as many turns of fine wire around the glass as possible. Keep it away from the lamps wires.
2. Connect it in series with a fixed resistor or MOV to simulate the circuit you propose.
3. Connect the ends of the coil wire to an oscilloscope and set it to trigger in single shot mode.
The neon has similar characteristics to a GDT except perhaps a lower ignition voltage but it is typically still > 100V. As it ignites the current through the gas will create a small magnetic field which the coil will convert to a voltage. It will allow you to see the discharge and hence get some idea of how it behaves differently in alternative configurations while maintaining complete voltaic isolation and safety.
Brian.
Brian.
