Results 1 to 5 of 5
    Newbie level 6
    Points: 1,406, Level: 8
    Sep 2010
    11
    1,406
    8
    Material used to make meter leads
    I have a question about the probe ends used for meter leads. I'm working on a project to make a probe adapter and was wondering if anyone knows what material is used to make the probe tip for meter leads? I was going to try and use SS finishing nails but I'm not sure I will be able to trust the solder/wire connection for strength.
    Is there a place I can source the rods? They would need to be the same diameter as a standard meter lead as the device I am making needs to fit into a set of holes on a power supply designed to take meter leads.
    Any help would be greatly appreciated.
    •   Alt8th November 2017, 16:42
      advertising
    Points: 69,545, Level: 64
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,367
    69,545
    64
    Re: Material used to make meter leads
    The ones I use here are nickel plated brass. Easy to machine, easy to solder and have good surface strength and corrosion resistance.
    Standard plugs are 4mm size.
    •   Alt8th November 2017, 17:04
      advertising
    Newbie level 6
    Sep 2010
    11
    1,406
    8
    Thanks. Any idea where to source them from?
    Also can I assume you meant 2mm since 4mm seems awfully thick for meter leads.
    •   Alt8th November 2017, 19:47
      advertising
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    11,367
    69,545
    64
    I meant the plugs for standard meter sockets and PSU sockets are 4mm. For the probe wire itself, you can get extra-flexible wire with many fine strands and silicone insulation which is far 'bendier' than normal PVC insulation.
    Points: 46,787, Level: 52
    Apr 2011
    Minneapolis, Minnesota, USA
    11,662
    46,787
    52
    For terminal posts on my homemade power supply, I used Radio Shack's multi-function banana jacks. They are rugged and have thumbscrews which grip a wire or pin-plug. The red & black banana plugs (with red & black flexible wires) came from a broken multimeter.
