The circuit is OK.
Why do you bother?
If you have special requirements on the circuit, then show us these specifications as values with units.
Btw: you say supply is +/-5V, but the circuit shows +/-10V.
If you ask for the "best way" you need to tell us what is "best" for you. Precision, cost, part count, size, noise, highest protection current...
Klaus
... and the zeners are for reducing the OPAMP supply voltage to +/-10V and don´t have (much) to do with protection of the inputs.the circuit shown above is just an exemple found in a book
A circuit without part values is only half of informations. (if ever)Here is my real circuit :
No. It will cause smoke, maybe fire, because there is no current limiting device.suppose a 20VPP signal in inputs of AD8138 , it will be clamped at 5.6 V? (this is what i want )
You need to calculate the voltage error caused by the leakage currents.is there a smarter way to do that ? , what about TVS bidirectional diode ?
Why don´t you limit the voltage directly at the amplifier inputs (like in the circuit of post#1?)
Then the resistors will limit the current.
Klaus
You say "almost". Then you know it isn't the same. I told you to connect the diodes directly at the amplifier input.
--> May I ask why you don't want to do this?
Klaus
You already have it.Can you show me with a drawing ?
