Results 1 to 11 of 11
    Points: 899, Level: 6
    Dec 2013
    36
    899
    Initializing Xilinx BRAM with image pixels
    I would like to initialize Xilinx BRAM (ROM) with image pixels, any ideas ?
    cheers,
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,442
    28,167
    40
    Re: Initializing Xilinx BRAM with image pixels
    Maybe you should read the Xilinx documentation, it states clearly how to initialize the content of a ROM using the block memory generator. Look for PG058.
    If I read it and then post the relevant information, it just means next time you won't read the documentation and will keep posting questions clearly answered in the documentation.
    You know Xilinx includes a program called Xilinx Documentation Navigator (installed by default), which makes it really really easy to search all their documentation for stuff you may have questions about.
    •   Alt6th November 2017, 21:53
      advertising
    Dec 2013
    36
    899
    Thank you for your help, but please next time don't lecture me.
    •   Alt7th November 2017, 11:03
      advertising
    Points: 35,441, Level: 45
    Jun 2010
    6,487
    35,441
    45
    Quote Originally Posted by Taki_comp View Post
    If you dont want a lecture, then please research properly before posting here.
    Dec 2013
    36
    899
    My question here: is there anyway to convert an image file into coe file ?
    •   Alt8th November 2017, 11:27
      advertising
    Member level 5
    Points: 563, Level: 5
    Apr 2017
    87
    563
    Yes it is. You have to write a program in your favorite language for converting bitmap into coe file. I did one for png to mif conversion.
  7. #7
    Dec 2013
    36
    899
    Let's say I use matlab, how can I do that ?
  8. #8
    Member level 5
    Apr 2017
    87
    563
    Just write a proper script in matlab:
    1) read a bitmap into array: https://uk.mathworks.com/help/matlab/ref/imread.html
    2) do a colour conversion from RGB to RGB565 or any other desirable format
    3) write to disk a text file in coe format.
  9. #9
    Dec 2013
    36
    899
    I already did the first two steps, for the last step I tried to display the values of the matrix in the command window but I can only display correctly few rows at a time correctly,I was wondering what may cause this problem ?
    •   Alt8th November 2017, 17:07
      advertising
  10. #10
    Full Member level 3
    Points: 2,428, Level: 11
    Nov 2009
    Pakistan
    183
    2,428
    11
    use .coe file to initialize your memory ROM at startup
  11. #11
    Dec 2013
    36
    899
    Thank you all for you replies, I solved the problem
