+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Member level 1
    Points: 899, Level: 6
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    Initializing Xilinx BRAM with image pixels
    I would like to initialize Xilinx BRAM (ROM) with image pixels, any ideas ?
    cheers,
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: Initializing Xilinx BRAM with image pixels
    Maybe you should read the Xilinx documentation, it states clearly how to initialize the content of a ROM using the block memory generator. Look for PG058.
    If I read it and then post the relevant information, it just means next time you won't read the documentation and will keep posting questions clearly answered in the documentation.
    You know Xilinx includes a program called Xilinx Documentation Navigator (installed by default), which makes it really really easy to search all their documentation for stuff you may have questions about.
    •   Alt6th November 2017, 21:53
      advertising
  3. #3
    Member level 1
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    Thank you for your help, but please next time don't lecture me.
  4. #4
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Quote Originally Posted by Taki_comp View Post
    If you dont want a lecture, then please research properly before posting here.
    •   Alt7th November 2017, 12:02
      advertising
  5. #5
    Member level 1
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    My question here: is there anyway to convert an image file into coe file ?
    •   Alt8th November 2017, 11:27
      advertising
  6. #6
    Member level 5
    Points: 563, Level: 5
    Join Date
    Apr 2017
    Posts
    86
    Points
    563
    Level
    Yes it is. You have to write a program in your favorite language for converting bitmap into coe file. I did one for png to mif conversion.
  7. #7
    Member level 1
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    Let's say I use matlab, how can I do that ?
  8. #8
    Member level 5
    Join Date
    Apr 2017
    Posts
    86
    Points
    563
    Level
    Just write a proper script in matlab:
    1) read a bitmap into array: https://uk.mathworks.com/help/matlab/ref/imread.html
    2) do a colour conversion from RGB to RGB565 or any other desirable format
    3) write to disk a text file in coe format.
  9. #9
    Member level 1
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    I already did the first two steps, for the last step I tried to display the values of the matrix in the command window but I can only display correctly few rows at a time correctly,I was wondering what may cause this problem ?
  10. #10
    Full Member level 3
    Points: 2,428, Level: 11
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    use .coe file to initialize your memory ROM at startup
    •   Alt17th November 2017, 07:15
      advertising
  11. #11
    Member level 1
    Join Date
    Dec 2013
    Posts
    36
    Points
    899
    Level
    Thank you all for you replies, I solved the problem
