Results 1 to 2 of 2
    Newbie level 6
    Points: 152, Level: 2
    May 2017
    12
    152
    Frequency Translation in MATLAB
    I have to design a generic baseband filter. I have a C++ code which gives me filter coefficients based on the input parameters such as no. of taps, no. of bands, band edges, amplitudes and weights(code uses remez exchange algorithm).
    I import the filter coefficients in MATLAB, do fft and plot the graph of it. I have to shift the graph such that its center is the center of baseband. I know that if I multiply filter coefficients with an exponential function and then do fft the resulting frequency domain output will be shifted in frequency [x(t)*e^j2*pi*f0 ==> X(f-f0)]. So to verify this I multiplied my filter coefficients with an exponential function and plotted it. But there is no change in the graph at all. Could someone tell me what am I doing wrong? I am posting the code and graph for reference.
    Code:-
    (b is the vector containing filter coefficients)
    N = length(b);
    fo = 200;
    b1 = b.*exp(1j*2*pi*fo);
    bins = [0:N-1];
    bins_hz = bins*fs/N;
    y = abs(fft(b1));
    subplot(2,2,1)
    plot(bins_hz, abs(fft(b)))
    subplot(2,2,2)
    plot(bins_hz, y)
    •   Alt27th October 2017, 10:28
      advertising
    Member level 5
    Points: 1,555, Level: 9
    Aug 2011
    82
    1,555
    9
    Re: Frequency Translation in MATLAB
    Hey,
    you are multiplying all samples with a constant phase instead of linear phase to get shift in frequency domain.
    you should do
    b1 = b.*exp(1j*2*pi*fo*(1:N)/N);
