[moved] How to clear Verilog HDL error
sugubai
Newbie level 6
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
module kj(j1,l1,j,k,clock,reset,q,qb,q1,qb1,b);
input j1,l1,j,k,clock,reset;
output reg q1,qb1;
output reg [3:0]q,qb,b,a;
always@(negedge clock)
begin
case({reset,j1,l1})
3'b100 :q1=q1;
3'b101 :q1=0;
3'b110 :q1=1;
3'b111 :q1=~q1;
default :q1=0;
endcase
qb1<=~q1;
end
always@ *
begin
if(q1==q1)
begin
kl JK1(j,k,clock,reset,q[0],qb[0]);
kl JK2(j,k,q[0],reset,q[1],qb[1]);
kl JK3(j,k,q[1],reset,q[2],qb[2]);
kl JK4(j,k,q[2],reset,q[3],qb[3]);
end
end
else if(q1==0)
begin
kl JK5(j,k,d,reset,q[0],qb[0]);
kl JK6(j,k,q[0],reset,q[1],qb[1]);
kl JK7(j,k,q[1],reset,q[2],qb[2]);
kl JK8(j,k,q[2],reset,q[3],qb[3]);
end
else if(q1==1)
begin
always@(reset)
begin
if(reset)
q <=4'b0000;
else if(q<4'b0101)
q <= q+1;
else
b=q[1]&&q[3];
end
end
else if (q1==~q1)
begin
always@(posedge clock)
begin
if(reset)
q <=4'b0000;
else if(q<4'b0011)
q <= q+1;
else
a=q[2]&&q[3];
end
end
endmodule
this is my verilog code i have some error in this...
Error (10170): Verilog HDL syntax error at kj.v(20) near text "("; expecting ";", or ","
Error (10170): Verilog HDL syntax error at kj.v(20) near text ")"; expecting ";", or ","
Error (10170): Verilog HDL syntax error at kj.v(21) near text "("; expecting ";", or ","
Error (10149): Verilog HDL Declaration error at kj.v(21): identifier "k" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(21): identifier "q" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(21): identifier "reset" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(21): identifier "qb" is already declared in the present scope
Error (10170): Verilog HDL syntax error at kj.v(21) near text ")"; expecting ";", or ","
Error (10170): Verilog HDL syntax error at kj.v(22) near text "("; expecting ";", or ","
Error (10149): Verilog HDL Declaration error at kj.v(22): identifier "k" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(22): identifier "q" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(22): identifier "reset" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(22): identifier "qb" is already declared in the present scope
Error (10170): Verilog HDL syntax error at kj.v(22) near text ")"; expecting ";", or ","
Error (10170): Verilog HDL syntax error at kj.v(23) near text "("; expecting ";", or ","
Error (10149): Verilog HDL Declaration error at kj.v(23): identifier "k" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(23): identifier "q" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(23): identifier "reset" is already declared in the present scope
Error (10149): Verilog HDL Declaration error at kj.v(23): identifier "qb" is already declared in the present scope
Info: Found 0 design units, including 0 entities, in source file kj.v
Info: Generated suppressed messages file C:/altera/90/quartus/new/kl.map.smsg
Error: Quartus II Analysis & Synthesis was unsuccessful. 19 errors, 0 warnings
Error: Peak virtual memory: 218 megabytes
Error: Processing ended: Sun Oct 22 09:44:22 2017
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 21 errors, 0 warnings
my error is above mentioned please help
Re: How to clear Verilog HDL error
modules are instantiated outside of an always/initial block.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
output reg q1,qb1;
begin
case({reset,j1,l1})
3'b100 :q1=q1;
3'b101 :q1=0;
3'b110 :q1=1;
3'b111 :q1=~q1;
default :q1=0;
endcase
qb1<=~q1;
end
always@*
begin
if(q1==q1)
end
always@*
begin
else if(q1==0)
kl JK5(j,k,clock,reset,q[0],qb[0]);
end
else if(q1==1)
begin
always@(reset)
begin
if(reset)
q <=4'b0000;
else if(q<4'b0101)
q <= q+1;
else
b=q[1]&&q[3];
end
end
else if (q1==~q1)
begin
begin
if(reset)
q <=4'b0000;
else if(q<4'b0011)
q <= q+1;
else
a=q[2]&&q[3];
end
end
endmodule
error
Error (10170): Verilog HDL syntax error at kj.v(20) near text "JK1"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(21) near text "JK2"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(22) near text "JK3"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(23) near text "JK4"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(27) near text "else"; expecting ";", or "@", or "end", or an identifier ("else" is a reserved keyword ), or a system task, or "{", or a sequential statement
Error (10170): Verilog HDL syntax error at kj.v(29) near text "JK5"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(30) near text "JK6"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(31) near text "JK7"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(32) near text "JK8"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at kj.v(35) near text "else"; expecting an identifier ("else" is a reserved keyword ), or "endmodule", or a parallel statement
Error (10112): Ignored design unit "kj" at kj.v(1) due to previous errors
Besides the lack of indentation of the code, which denotes a certain sloppiness, there are several strange stuffs even for those who are not familiar with verilog language.
begin
else if(q1==0)
if(q1==q1)
If you really want to be helped, you have to make a little more effort to solve these problems by yourself
There are an excessive number of problems with this code, literally too many to point out.
To name just a few:
  • no formatting of the code
  • utterly useless names for everything (other than clock and reset)
  • lack of comments
  • non-Verilog 2001 port syntax
  • a case statement for a simple register description
  • using the negedge of a clock for no good reason
  • using always blocks for instantiating the k1 module
  • the earlier pointed out if (q1==q1), FYI this is always true
etc, there are more but, that is only half way through the file.
Apparently you don't understand that Verilog is a Hardware Description Language (HDL) and you should understand the logic you are trying to describe, not write any random code and hope it can be synthesized to logic.
IIRC, (q1 == q1) is false for q1 = 1'bx.
always@*
begin
if(q1==q1)
Okk sir.. i am the beginner of the verilog so, now only i am just learned about it..anyway thank you sir
