eagle1109
Full Member level 6
- Joined
- Nov 20, 2014
- Messages
- 390
- Helped
- 4
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Saudi Arabia
- Activity points
- 5,912
Hello,
1. I'm trying to control the oscillator speed but I don't see any results. Where is the problem? I want to run 125kHz internal clock speed.
2. The LED also is not blinking! I don't know where is the problem, the code on the simulator is working but I can't control the oscillator speed.
3. The variables don't show on the variables window in debugging, while running debugging.
I'm using MPLAB X v3.30.
btfss or btfsc work fine for input testing to light an LED as a result, but blinking doesn't work, I increased the delay lines but its effect show on the debugger i/o window, but on the breadboard it isn't.
This is my code:
This is my code:
; PIC18F4550 Configuration Bit Settings
; ASM source line config statements
#include "p18F4550.inc"
; CONFIG1L
CONFIG PLLDIV = 1 ; PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
CONFIG CPUDIV = OSC1_PLL2 ; System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
CONFIG USBDIV = 1 ; USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
; CONFIG1H
CONFIG FOSC = INTOSC_EC ; Oscillator Selection bits (Internal oscillator, CLKO function on RA6, EC used by USB (INTCKO))
CONFIG FCMEN = ON ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
CONFIG IESO = ON ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode enabled)
; CONFIG2L
CONFIG PWRT = OFF ; Power-up Timer Enable bit (PWRT disabled)
CONFIG BOR = OFF ; Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
CONFIG BORV = 3 ; Brown-out Reset Voltage bits (Minimum setting 2.05V)
CONFIG VREGEN = OFF ; USB Voltage Regulator Enable bit (USB voltage regulator disabled)
; CONFIG2H
CONFIG WDT = OFF ; Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
CONFIG WDTPS = 32768 ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
CONFIG CCP2MX = OFF ; CCP2 MUX bit (CCP2 input/output is multiplexed with RB3)
CONFIG PBADEN = ON ; PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
CONFIG LPT1OSC = OFF ; Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
CONFIG MCLRE = ON ; MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
; CONFIG4L
CONFIG STVREN = OFF ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will not cause Reset)
CONFIG LVP = OFF ; Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
CONFIG ICPRT = OFF ; Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
CONFIG XINST = OFF ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
CONFIG CP0 = OFF ; Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
CONFIG CP1 = OFF ; Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
CONFIG CP2 = OFF ; Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
CONFIG CP3 = OFF ; Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
; CONFIG5H
CONFIG CPB = OFF ; Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
CONFIG CPD = OFF ; Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
; CONFIG6L
CONFIG WRT0 = OFF ; Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
CONFIG WRT1 = OFF ; Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
CONFIG WRT2 = OFF ; Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
CONFIG WRT3 = OFF ; Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
; CONFIG6H
CONFIG WRTC = OFF ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
CONFIG WRTB = OFF ; Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
CONFIG WRTD = OFF ; Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
; CONFIG7L
CONFIG EBTR0 = OFF ; Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
CONFIG EBTR1 = OFF ; Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
CONFIG EBTR2 = OFF ; Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
CONFIG EBTR3 = OFF ; Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
; CONFIG7H
CONFIG EBTRB = OFF ; Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
delay1 res 1
delay2 res 1
delay3 res 1
RES_VECT CODE 0x0000 ; processor reset vector
movlw 0X08
movwf TRISD
clrf LATD
clrf PORTD
movlw 0X10
MOVWF OSCTUNE
movlw 0X1E
MOVWF OSCCON
GOTO START ; go to beginning of program
; TODO ADD INTERRUPTS HERE IF USED
MAIN_PROG CODE ; let linker place main program
START:
; btfsc PORTD,3
call blink
GOTO START
blink:
bsf PORTD,2
call Delay
bcf PORTD,2
call Delay
Delay:
movlw 0xff
movwf delay2
loop1:
movlw 0xff
movwf delay1
loop2:
decfsz delay1
goto loop2
decfsz delay2
goto loop1
return
END
