brunoaduarte
Newbie level 6
Hi!
My Asus AC Adaptor (Input: 100-240V / Output: 19V) - Model AD890026 that stopped working after a drop.
- I've checked the fuse and it's ok.
- Made a visual inspection and all the solder seems fine.
- Removed and tested the yellow MPX40 part with a multimeter and it measures 283.7 nF
- The big 47 uF / 400V capacitor charges with ~190V when i connect it to the wall plug.
- No 19V output on the PCB.
Can someone help me finding the problem with it ? Where should i start looking and/or which tests could i make here ?
I've attached some pictures (including a ZIP file with the high res images).
Thanks!
Thanks!
