svip
Newbie level 2
Synopsys dedign vision and generic (VHDL)
Hello, i write and synthetize VHDL for fpga since more than 10 year but now i am new with ASIC design
I have problem during the Elaboration of my design cause the presence of generic. is there some strange procedure to use in case of generic in synopsys?
Thank you
this is a simple example, in a top level architecture i use two times this simple generic counter
I SOLVE using manual script, the GUI seems to have a bug, launching manua script all work perfectly
Is it possible?
Thank you
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_signed.all;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity generic_counter_bis is
generic(
N_bit : natural:=8;
hit_gen: natural:=4;
N_reset: natural:=6
port(
clk,rst,enable:in std_logic;
hit:out std_logic;
output:out std_logic_vector(N_bit-1 downto 0)
end generic_counter_bis;
architecture Behavioral of generic_counter_bis is
signal acc: std_logic_vector (N_bit-1 downto 0);
--constant hit_gen_1: std_logic_vector:=conv_std_logic_vector(hit_gen,N_bit);
begin
process(clk,rst)
begin
if rst='1' then
acc<=(others=>'0');
elsif clk='1' and clk ' event then
if enable='1' then
if acc=conv_std_logic_vector(N_reset,N_bit) then --if acc=N_reset
acc<=(others=>'0');
else
acc<=acc+1;
end if;
end if;
end if;
end process;
hit_generator: process(acc)
begin
if acc=conv_std_logic_vector(hit_gen,N_bit) then
hit<='1';
else
hit<='0';
end if;
end process;
output<=acc;
end Behavioral;
Is it possible?
