Results 1 to 10 of 10
    Full Member level 2
    Points: 881, Level: 6
    Feb 2016
    144
    881
    Improved current mirror
    I do not understand "The circuit on the right is a feedback amplifier with loop gain T. Since all time constants in that loop are of the same order of magnitude, they create a system with several poles"
    Could anyone point me to some maths reference / equations ? Razavi book does not mention about the circuit on the right though.
Name:	screenshot_2017-10-12 at 4.23.01 PM.jpeg
    •   Alt12th October 2017, 10:37
      advertising
    Full Member level 2
    Feb 2016
    144
    881
    Re: Improved current mirror
    How do I derive the feedback loop gain T = (gm1)*(Rin) ?
    Points: 234,575, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,534
    234,575
    100
    The improved Wilson current mirror is discussed in Gray/Hurst/Lewis/Meyer Analysis and Design.
    Full Member level 2
    Feb 2016
    144
    881
    Thanks. Let me start with 3T Wilson mirror in BJT implementation.
Name:	Screenshot from 2017-10-13 12-21-51.png
    A feedback path is thus formed that regulates IC3 so that it is nearly equal to the input current, reducing the systematic gain error caused by finite βF.
    systematic gain error due to finite βF ?
    •   Alt13th October 2017, 05:30
      advertising
    Junior Member level 3
    Points: 845, Level: 6
    Nov 2013
    31
    845
    if you use a simple bipolar current mirror, the output current is smaller than the input current because the base currents are subtracted from the input current to generate input bias currents for the 2 transistors. The sys gain error is 1-Iout/Iin, and if you can reduce the base currents the gain error will decrease. You can reduce the base currents by increasing the BF, but for bipolar devices it is finite. And gain error will also occur by the Early effect. At this circuit the explanation is similar, but more complicated because of the feedback.
    Full Member level 2
    Feb 2016
    144
    881
    How would I get to this error expression ?
  7. #7
    Nov 2013
    31
    845
    Gain Error = Ideal Gain (1) - Real Gain (Iout/Iin)
    For 1:1 current mirror. For 1:M current mirror it is M-Iout/Iin.
    And about Wilson current mirror you can read more here: https://wiki.analog.com/university/c...ext/chapter-11
    •   Alt13th October 2017, 12:15
      advertising
  8. #8
    Full Member level 5
    Points: 3,262, Level: 13
    Jul 2006
    USA
    253
    3,262
    13
    For the loop gain T, you can image that from the drain node of M3, the impedance is 1/gm3 +
    Rin=ro1+ 1/gm3.
    For M1, from its gate to its drain, the gain is gm1*ro1, which is aproximately gm1*Rin. Also, from the drain of M1 to the gate of M3, to the source of M4, the gain is 1, so the total loop gain T is around gm1*Rin.
  9. #9
    Full Member level 2
    Feb 2016
    144
    881
    a) Why is the gain from the drain of M1 to the drain of M3 = 1 ?
    b) In most CMOS applications, the use of resistive source degeneration to reduce noise and improve matching is restricted due to headroom constraints. Could anyone elaborate on this statement extracted from "Ultra High-Compliance CMOS Current Mirrors for Low Voltage Charge Pumps and References" ?
    Ultra High-Compliance CMOS Current Mirrors for Low Voltage Charge Pumps and References.pdf
  10. #10
    Full Member level 5
    Jul 2006
    USA
    253
    3,262
    13
    Source follower, the gain is around 1.
