+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Advanced Member level 2
    Points: 3,836, Level: 14
    Join Date
    Apr 2011
    Posts
    530
    Points
    3,836
    Level
    14
    What is the purpose of the Avalon-MM master and Avalon-MM slave templates?
    The Intel website has these:
    https://www.altera.com/support/suppo...avalon-mm.html
    https://www.altera.com/support/suppo...ory-slave.html
    What is the actual purpose of these templates?
    •   Alt9th October 2017, 10:46
      advertising
  2. #2
    Member level 5
    Points: 570, Level: 5
    Join Date
    Apr 2017
    Posts
    87
    Points
    570
    Level
    Re: What is the purpose of the Avalon-MM master and Avalon-MM slave templates?
    Yo can write your own component using Avalon-MM bus and late use it with NIOSII softcore.
    •   Alt9th October 2017, 10:48
      advertising
  3. #3
    Advanced Member level 5
    Points: 35,461, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,492
    Points
    35,461
    Level
    46
    Avalon is just a bus specification. You can use it to connect any components together. It is very similar to AXI from ARM.
    •   Alt9th October 2017, 10:59
      advertising
  4. #4
    Join Date
    Apr 2011
    Posts
    530
    Points
    3,836
    Level
    14
    OK, while I understand the purpose of the Avalon-MM slave, what about the master template? Won't the master always be a Nios II? Then why do we need this Avalon-MM master template?
  5. #5
    Member level 5
    Join Date
    Apr 2017
    Posts
    87
    Points
    570
    Level
    You can have more the one master at Avalon-MM bus. It can be very useful if you want to transfer a large chunk of data between network interface and memory without using CPU resources.
    •   Alt9th October 2017, 12:32
      advertising
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,492
    Points
    35,461
    Level
    46
    Quote Originally Posted by matrixofdynamism View Post
    You can build a system using Avalon without a Nios, or any CPU. So something needs to be a master.
