el00
Member level 5
Hi, I am doing experiments with wifi antennas in noisy environment.
I need to place 2 antennas close each other, but each about 20cm far from the module.
The final goal is to build a lan extender which will cross a special barrier, I will not enter into details.
BTW, the difficult part is to find wifi bridge which are OEM, so that I can solder a coax with a custom built antenna.
The only one that I found is "WLn-LINK-OEM" (easy to find on the web), but I cannot find alternatives.
I browsed digikey, farnell, rs-components but I did not find any alternative that I can easily buy from distributors.
Any suggestion?
Any suggestion?
