+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 14, Level: 1
    Join Date
    Oct 2017
    Posts
    Points
    14
    Level
    How to combine bitstreams (thrid party IP cores) to use it in main design?
    In FPGA design when we buy Intellectual property (IP) from a vendor I assume they provide the IP core in a form of bitstream file.
    My question is how we actually combine these different bitstream from different vendor and configure it in our system?
    •   Alt6th October 2017, 10:58
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,461, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,492
    Points
    35,461
    Level
    46
    Re: How to combine bitstreams (thrid party IP cores) to use it in main design?
    It depends what the IP is.
    If it is a complete design, then yes, it will be a bitstream. This cannot be combined with anything else as it would program the entire chip.
    But you can get IP in the form of source code, encrypted source code, netlist (synthesis or post fit) which can all be compiled into a design. Here, you dont get provided with a bit stream, you compile the provided source.
    •   Alt6th October 2017, 11:11
      advertising
  3. #3
    Points: 5,385, Level: 17
    Join Date
    Apr 2016
    Posts
    1,133
    Points
    5,385
    Level
    17
    Really unlikely that you will get a bitstream for an IP.
    Really, I am not Sam.
