+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 4
    Points: 887, Level: 6
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    [Synth 8-27] complex assignment not supported
    I have a segment of vhdl code as follows:
    [syntax=vhdl]
    if option = '0' then
    addr1_1 := 4*addr1_2; ---4xAddress
    if s_count2 = 0 then
    block_array(block_index) <= addr1_1;
    block_index := block_index + 1;
    s_count2 <= 1;
    elsif s_count2 = 1 then
    block_array(block_index) <= addr1_1 + 1;
    s_count2 <= 2;
    elsif s_count2 = 2 then
    block_array(block_index) <= addr1_1 + 2;
    s_count2 <= 3;
    else
    block_array(block_index) <= addr1_1 + 3;
    option <= '1';
    s_count2 <= 0;
    block_addr <= 0;
    end if;
    else
    addr1_1 := 4*block_array(block_addr);
    if addr1_1 <= b1'high then
    db_a1 := block_addr;db_a2 := block_addr + 1;
    s_count2 <= 1;
    s_count2 <= 2;
    s_count2 <= 3;
    else
    if b(block_array(block_addr)) = '1' then
    block_array(block_addr TO 339) <= block_array(block_addr+1 TO 340);
    block_index := block_index - 1;
    else
    block_addr <= block_addr + 1;
    end if;
    s_count2 <= 0;
    end if;
    end if;
    end if;
    [/syntax]
    When I synthesis the code, I get the following error at line 42:
    How to rectify this?
    •   Alt5th October 2017, 10:41
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Re: [Synth 8-27] complex assignment not supported
    what is "block array" ?
    But it looks like you're trying to set many values in a shift register (or is it a ram?) at once - and that is not possible in a physical ram.
    •   Alt5th October 2017, 11:09
      advertising
  3. #3
    Member level 4
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    [syntax=vhdl]
    TYPE block_addr_array is array(0 to 340) of integer range 0 TO N*N/4-1;
    signal block_array : block_addr_array;
    SIGNAL b : STD_LOGIC_VECTOR(N*N/4 - 1 downto 0)
    [/syntax]
    It is an array, not a RAM.
    The operation can be illustrated as follows:
    suppose: addr1_2 = 1;b(5) = '1' then
    After 4 clock cycles, block_array is like this
    [4 5 6 7]
    After 8 clock cycles...
    [4 5 6 7 16 17 18 19]
    After 12 clock cycles...
    [4 5 6 7 16 17 18 19 20 21 22 23]
    But in the 12th clock cycle, as b(5) = '1', the contents should be like this
    [4 6 7 16 17 18 19 20 21 22 23]
    To achieve this I have tried to partially shift block_array, because 4 is at the same position.
    •   Alt5th October 2017, 11:39
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    What it is not liking is using the block_addr as the base index in the shift. Because block_addr could by any value in the array, it needs to build circuits for every possible version of block_addr.
    From this and your other post, it really feels like this is not really a hardware friendly design, and probably taking a software approach.
    Did you draw out the circuit you expect before writing any code? Did you think about pipelining the design? did you create a hardware friendly version of your compression/decompression algorithm? Did you even assess if it was hardware friendly, or if it would work better in a processor.
    This operation you show in the code is something that is more likely suited to a CPU, not hardware.
  5. #5
    Advanced Member level 3
    Points: 4,949, Level: 16
    Join Date
    Feb 2015
    Posts
    825
    Points
    4,949
    Level
    16
    The tools don't currently understand how to do this.
    One possible way to do this would be to have the expression "x", the shifted version "x<<1", and then a mask. y = (mask&x) | ((~mask)&(x<<1)).
    This is probably still a multi-cycle operation as the logic for mask is at least equivalent to a 340 bit addition with some extra fanout. Likewise, keeping 340 integers in registers can use excessive resources depending on the value of N.
