+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 1
    Points: 147, Level: 1
    Join Date
    Aug 2017
    Posts
    14
    Points
    147
    Level
    problem with signing a 2d array to another 2d array
    count and signal_out are 2d arrays 32bit*32bit.
    in this code i want to count the number of toggles of the signal sample(27) by count(27) and put the result in signal_out(27).
    U_27 : counter port map (clk => SAMPLE(27),  count(27) =>  signal_out(27));
    but i receive an error which says "(vcom-1193) Formal "count" length is 32; number of individual associations is 1."
    i initialized the signal_out array to zero but it didn't help.
    please help me to correct this error.
    thanks
    •   Alt4th October 2017, 11:03
      advertising
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: problem with signing a 2d array to another 2d array
    Clk => sample(27)
    What a waste of clock buffer resources. Maybe you should learn what a clock enable is.
    Out of context code won't help you get an answer, you should post all the code.
