+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 1
    Points: 1,308, Level: 8
    Join Date
    Aug 2013
    Posts
    114
    Points
    1,308
    Level
    8
    problem by vivado in Rom Extraction from file !
    I have a code for extracting a ROM from a text file. I'v used it successfully in ISE 14.7 on a spartan6. synthesize and implementation was OK.
    but now I want to use it on an artix project by vivado. unfortunately vivado can not synthesize the code currently .
    the code is as below:
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_unsigned.all;
    use std.textio.all;
    entity My_Rom is
    port(	iClk		:in std_logic;
    		iAddr		:in std_logic_vector(9 downto 0);
    		oData		:out std_logic_vector(15 downto 0)
    end My_Rom;
    architecture Behavioral of My_Rom is
    	type tRom is array (0 to 1023) of std_logic_vector(15 downto 0);
    	impure function RomExtc (RomFileName : in string) return tRom is
    		FILE RomFile     	: text is in RomFileName;
    		variable L			: line;
    		variable RomData    : tRom;
    		variable iData    	: integer;
    		variable qData    	: integer;
    	begin
    		report "Making Mapping_Rom:";
    		-- for ii in tRom'range loop
    		for ii in 0 to 1023 loop
    			readline (RomFile, L);
    			report "L: " & L.all;
    			iData:=0;
    			read (L, iData);
    			report "iData= "&integer'image(iData);
    			RomData(ii):=conv_std_logic_vector(iData,16);
    		end loop;
    		return RomData;
    	end function;
    	constant cRom : tRom := RomExtc("Rom.coe");
    	signal sAddr	:std_logic_vector(9 downto 0):=(others=>'0');
    	signal sData	:std_logic_vector(15 downto 0):=(others=>'0');
    begin
    	process(iClk)
    	begin
    		if rising_edge(iCLk)then
    			sAddr		<=iAddr;
    			sData		<=cRom(conv_integer(unsigned(sAddr)));
    		end if;--Clk Rising
    	end process;
    	-- sData		<=cRom(conv_integer(unsigned(sAddr)));
    	oData	<=sData(15 downto 0);
    end Behavioral;
    can any body help me plz.
    the version of vivado : 2015.4
    •   Alt2nd October 2017, 11:50
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,548, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,332
    Points
    34,548
    Level
    45
    Re: problem by vivado in Rom Extraction from file !
    What do you mean by "it cannot synthesise the code currently"?
    What Error messages are you getting? What problems are they exactly? Does the ROM appear to be filled with incorrect values? Is thje Rom.coe file in the correct location in the project?
    Please post the errors
    •   Alt2nd October 2017, 14:20
      advertising
  3. #3
    Full Member level 1
    Join Date
    Aug 2013
    Posts
    114
    Points
    1,308
    Level
    8
    Not any ROM extracted. in vivado synthesize finishes with NO Error but not any ROM is extracted as report.
    By opening synthesize result netlist and viewing schematic I see no ROM extracted and all output port is connected to gnd.
    I've attached ISE and vivado synthesize report.
    vivado_report.txt
    ISE_Report.txt
    •   Alt2nd October 2017, 14:28
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,332
    Points
    34,548
    Level
    45
    The report says the address port is unconnected - so no surprise it is removed.
  5. #5
    Full Member level 1
    Join Date
    Aug 2013
    Posts
    114
    Points
    1,308
    Level
    8
    Quote Originally Posted by TrickyDicky View Post
    can u say, why ISE has no errors and extracts a ROM? but vivado not!
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,332
    Points
    34,548
    Level
    45
    Quote Originally Posted by Port Map View Post
    Im guessing because in ISE the rom has an address connection, but in your Vivado project you didnt connect the address to anything.
    So the problem is NOT in the code you posted, it is elsewhere. You need to connect the address port of the rom to something.
    •   Alt2nd October 2017, 15:18
      advertising
  7. #7
    Full Member level 1
    Join Date
    Aug 2013
    Posts
    114
    Points
    1,308
    Level
    8
    this is not true, because I "set as top" in both(ISE / vivado), then there is no need to connect iAddr or iClk to anything!
    I'v attached the projects of Vivado and ISE for who is interested in testing the design.
    Test_Prj.rar
