biswajitdas49
Member level 3
- Joined
- May 17, 2012
- Messages
- 55
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- WEST BENGAL,INDIA
- Activity points
- 1,726
hello,
I have a problem with pic12f1571 in mplabx v4.01. I write this code which gives build error that is-
"CLEAN SUCCESSFUL (total time: 542ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'E:/BOOKS/Electronics/PROTIUS SIMULATION/PIC12F1571 PWM BASED RGB CONTROL/code/pwmrgb.X'
make -f nbproject/Makefile-default.mk dist/default/production/pwmrgb.X.production.hex
make[2]: Entering directory 'E:/BOOKS/Electronics/PROTIUS SIMULATION/PIC12F1571 PWM BASED RGB CONTROL/code/pwmrgb.X'
"C:\Program Files (x86)\Microchip\MPLABX\v4.01\mpasmx\mpasmx.exe" -q -p12f1571 -l"build/default/production/pwmrgb.lst" -e"build/default/production/pwmrgb.err" -o"build/default/production/pwmrgb.o" "pwmrgb.asm"
"C:\Program Files (x86)\Microchip\MPLABX\v4.01\mpasmx\mplink.exe" "C:\Program Files (x86)\Microchip\MPLABX\v4.01\mpasmx\LKR\12f1571_g.lkr" -p12f1571 -w -m"dist/default/production/pwmrgb.X.production.map" -z__MPLAB_BUILD=1 -odist/default/production/pwmrgb.X.production.cof build/default/production/pwmrgb.o
MPLINK 5.08, LINKER
Device Database Version 1.38
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.org_0' can not fit the absolute section. Section '.org_0' start=0x0000f000, length=0x00000008
Errors : 1
nbproject/Makefile-default.mk:124: recipe for target 'dist/default/production/pwmrgb.X.production.hex' failed
make[2]: Leaving directory 'E:/BOOKS/Electronics/PROTIUS SIMULATION/PIC12F1571 PWM BASED RGB CONTROL/code/pwmrgb.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/BOOKS/Electronics/PROTIUS SIMULATION/PIC12F1571 PWM BASED RGB CONTROL/code/pwmrgb.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [dist/default/production/pwmrgb.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 2s)"
I did not find any template file of this IC,so I copied from another template from 'PIC12F1822' and change all the portion of PIC12F1822 to PIC12F1571. I just want to see that it would run or not, but it showed me the error.please somebody help, it's really important for me to build and run this to see that the template really works for my further programming. thanks for reading my problem!!!
MPLINK 5.08, LINKER
Errors : 1
