Design of Single stage OTA with following specs
prateekj212
I am referring the design prcoedure from Philip Allens textbook from chapter 5.2.7. I am designing a single stage OTA with differential amplifier and current mirror load. My specifications are below:
DC Gain Av = 40 dB minimum
Gain-Badnwidth = 40MHz minimum
Large signal cut off frequency 200 kHz
Output common mode typical voltage 0.9 V
Input common mode range 0.3 to 1.4 V
Supply voltage VDD 1.8V
Load capacitance 1pF
I am achieving the gain of 40 dB between 0.3 to 1.4V but my output common mode is stuck at 1.247 V which is not desired. I am using Cadence design tools. Here is the circuit below.
I am using NMOS differential pair.
Please help with proceeding with the implementation.
... but my output common mode is stuck at 1.247 V which is not desired.
With this architecture, your output common mode voltage (OCMV) is determined by the W/L ratio of your PMOSFETs to that of your NMOSFETs: W/L(PMOSFETs) / W/L(NMOSFETs). For an OCMV≈0.9V you'll have to reduce this ratio probably far below 1 .
Find here an example for a (W/LPMOS)/(W/LNMOS) 1:20 ratio : 180nm-1stage-OTA-40MHz-1pf-OCMR-0,9V.png
Unfortunately, your ICMR will probably be restricted at the lower end.
Reactions: e0e0
    e0e0
Hi
Thank you very much for the suggestion. I tried the simulation with the dimensioning mentioned by you. I achieve a output common mode value of around 900m but my gain suffers now. way less than 40 dB. I am not sure how you got 47 dB with your simulation. I am using the exact same dimenisions for the circuit PMOS and NMOS. Do i Need to increase the current beyond 10u?
Appreciate your help.
... but my gain suffers now. way less than 40 dB. I am not sure how you got 47 dB with your simulation. I am using the exact same dimenisions for the circuit PMOS and NMOS.
Different process? In any case different models!
No, quite the contrary - if you have enough UGB. See the following hints:
If the UGB isn't high enough, you can try and enlarge the W/L ratios of the 4 amp-MOSFETs, all by the same factor.
If this doesn't help sufficiently, you'll need a further amplifier stage.
Ok I will try this. From my previous reply I have attached a graph which shows the output common mode voltage. How can I shift the graph to the right? I want the output common mode value to be around 900 mV for input of 0.3 to 1.4V. Atleast thats what is in my specification. If this is not possible with a single stage OTA, please mention other modifications.
Thank you
And yes, the process is different because I have different vth0n and vth0p values. 0.3 V and -0.46V respectively.
Indeed, I warned you above that your ICMR will probably be restricted at the lower end.: you can't avoid that with this architecture. To get down with the ICMR range to 0.3V (for OCMV=0.9V), you must probably use the inverse structure: pFET inputs:
pFET-diff-amp.png Try it!​
Right, that's a bit different. And what's your process size?
