hanen88
Member level 1
Hi;
When i used both of Harmonic Balance and Phase noise controler, i display these curve as bellow:
However, the matter that i should determine the phase noise at 1MHZ or these simulation results prove that the curve finish in 100MHZ . I ask what can i do to obtain the lower value in 1 MHZ nad if some adjustement of the phase noise set up should done to obtain good results. I'm so gratefull to answer me.
Sincerly;
Sincerly;
