help with pc usb mouse
mohsen 2012
Member level 4
help qbout pc usb mouse
hello guys i have a problem with optical mouse usb , the red led have a low luminous and the mouse '' not recognized '' when i plug it in pc !!
i try to replace the red led but the problem dont resolve !!
please help me and thanks
Re: help qbout pc usb mouse
1. Try another USB port.
2. Try another mouse
3. Try another PC
The brightness of the red led has nothing to do with getting recognized.
Ok
But i want to repair it .
Maybe the 12 pin IC is bad
Some mice have a USB interface IC and an optical sensor IC. Some have them combined into one IC. Tell us which kind it is and if possible send us pictures of the top and bottom of the internal board and any numbers on the ICs.
The brightness of the LED is controlled by the optical IC but it needs to receive commands through the USB cable before it will start working.
Brian.
The normal fault with wired mice is that one of the wires in the cable where it enters the mouse body goes open circuit. Check the continuity of all of the conductors in the cable.
OK, thats a single IC type, the USB interface is inside the optical IC.
Do as Pjmelect suggests first, broken cables are common because by their nature they are flexed all the time and tend to fracture. If the cable is broken, you can take one from any other USB data device (avoid USB charging cables because sometimes not all the wires are present) and fit it instead. Make sure you note which point on the board goes to which pin on the USB plug before disconnecting because there is no standard for color coding the wires, they may be different from one cable to another.
If the cable isn't faulty, throw it away and buy a new mouse. You will not be able to get a replacement IC and even if you could there may be a minimum order of thousands and at unreasonable price.
Brian.
I resolve the problem by changing usb cable
Thank's
