Breakdown Voltage of TSMC0.18um CMOS
pancho_hideboo
Advanced Member level 5
Real Homeless
I can not find out descriptions about following breakdown voltage in TSMC0.18um CMOS documentations.
wBvg : gate oxide breakdown voltage
wBvds : drain-source breakdown voltage
However I can find only supply voltage specification in documents.
Specification are :
1.8Volts + 10% = 2.0Volts
3.3Volts + 10% = 3.6Volts
https://www.edaboard.com/showthread.php?t=289258#4
https://www.edaboard.com/showthread.php?t=101992#2
https://www.edaboard.com/showthread.php?t=82605
Are they true for wBvg and wBvds ?
wBvg=2.0Volts, wBvds=2.0Volts for 1.8Volts MOSFET
wBvg=3.6Volts, wBvds=3.6Volts for 3.3Volts MOSFET
For 1.8Volts-MOSFET and 3.3Volts-MOSFET, what values are forced as these breakdown voltage ?
These voltages are reliability rules and probably far
from "hard breakdown" - more likely hot carrier (Vds)
and gate oxide integrity (Vgs, Vgb, Vgd) lifetime
basis.
You -might- find some applications collateral at TSMC
or be able to coax some from their foundry applications
folks.
True D-S breakdown character will change a lot with L
and with "voltage family" and any degrees of freedom
attending drain extensions (digital vs analog/RF) etc.
You can bet it happens further out than the "foam
helmet" user design limit values, but how much so is
going to swing wide.
Gate oxide breakdown depends (mainly) on its thickness tox. TSMC 0.18um tox=4.1nm, so it should be good for BVg≈4V (s. PDF below), i.e. wBvg=2.0Volts for 1.8Volts MOSFETs should be conservative, i.e. safe.
View attachment Deep_Submicron_CMOS_Circuit_Design---Simulator_in_hands_p.3-39.pdf
... as well as wBvds=2.0Volts for 1.8Volts MOSFETs, even for Lmin.
I'm not sure about the 3.3Volts MOSFET oxide thickness (AFAIR 7nm), so the wBvg=3.6Volts for 3.3Volts MOSFETs should also be far away from its assumable breakdown voltage BVg≈7V. As dick_freebird stated above, wBvds increases with L , that's why I think Lmin(3.3Volts MOSFET) > Lmin(1.8Volts MOSFET).
