Modelsim: How to find and add every signal that contains something in the name ?
alexis57
Newbie
I think there is a lack of documentation for what I want to do.
I am using Modelsim SE 10.5 and I would like to add waves/signals from my design automatically depending on the name.
For example I'd like to add every signal of every instance that contains `fifo`.
The `find` command with `/*/*..` may work but I need to know how deep each instance is and it's not possible to add wave from the find command.
For now, what I am doing:
  1. Adding everything `add wave -r /`
  2. Saving in a `wave.do`
  3. Using linux shell with `cat wave.do | grep fifo > newwave.do` but it's not efficient and I'll get also the signals/nets naming `fifo`.
**I guess it's possible directly with Tcl but how ?**
I couldn't find the `Tcl object` that contains the whole compiled project.
I was surprised that this is not documented because it's very useful when the design is big.
Thank you very much.
refering to the "add wave" command and section on wildcard characters in the modelsim command reference manual, this will probably do it:
add wave -recursive fifo/*
Yes I have tried this but it didn't work.
# (vish-4014) No objects found matching 'fifo/*'.
Same for:
add wave -recursive fifo*/*
add wave -recursive *fifo/*
add wave -recursive *fifo*/*
But `add wave -noupdate -radix hexadecimal /top_instance/group_instance/scfifo_instance/*` works, this means there are FIFOs.
Thank you TrickyDicky.
