duel input LDO (1 dc and other li-ion battery ) with charging ability
mot1639
dear all ,,
i start design my pcb project , i lock for my power side in my project an DC to Dc convertor IC , with battery input and same time it can be charge if DC connect to my circuit or start feed the circuit if there no DC input , the current i look for is 1A ,
i know with some ic it can be done, but i look for single chip which can do all this ,, please advice ..
regards
current is 1A:
charge current, power supply current, application current?
But voltages you keep totally in secret....
...Makes it difficult to give good assitance.
thank you mr klaus , the volt it range between 3.4 to 5v is ok with me , thank you in advance
regards
You like to post riddles and keep us busy:
You urgently need to tell what "currents" and "voltages" you are talking about.
Without these informations it´s useless to discuss.
Have you looked at dual input power prioritizers?
