Is that considered a combinatorial loop and how bad is it ?
joul
Let's say we have
entity ent  is
  port (
  a : out std_logic
end ent;
architecture archi of ent is
  signal s1,s2 : std_logic;
begin
  s2 <= <some condition>;
  [B]s1[/B] <= '1' when s2 = '0' [B]or s1 = '1'[/B] else '0';
  a <= s1;
end archi ;
Basically I want a to go to '1' if s2 is '0' and stay that way when s2 goes back to '1'.
Let's say there is no clock available.
It works as expected on a FPGA but is that considered a combinatorial loop and is it bad practice ?
It would only be a comb loop if S2 also was dependent on a, so as long as that's not the case, then no problem.
Reactions: FvM
    FvM
Thanks for your answer.
So the fact that s1 is part of the condition in its own assignment is not a problem ?
s1 <= '1' when s2 = '0' or s1 = '1' else '0';
O.K., that is in fact a combinational loop. But it makes no sense because s1 is never reset.
That's the point, it should never go back to '0' once it goes to '1'. Is this logic safe or not ?
There must be at least a power-on reset. Apart from this point it's safe. You have to assure that s2 or the preceding logic can't generate glitches.
Reactions: joul
    joul
To clarify, s2 is set on power on, so everything should be fine right ?
Yes, but the only way to reset it is power cycle the device.
Must admit missed the S1 reference to itself. The first time
First point is that you need to enforce a low power-on state of s1, otherwise the logic could be optimized to "nothíng" by the synthesis tool.
I would prefer a dedicated reset input though.
Let's say we have
... is it bad practice ?
You need to explain why you do not have any clocks in this design. This sounds like weird academics doing thing with no understanding of FPGAs -- who would also resent that statement because they have PHDs and thus could understand anything even though they intentionally wont.
